gas pedal sticking - SaabCentral Forums
Old 10th August 2007
Drew'sSaab Drew'sSaab is offline
My Saabs: 1997 Saab 900SE Turbo
Default gas pedal sticking
when i drive my car on the hwy and after i get off the hwy for about a mile or 2...the gas pedal sometimes will stick in its position for a few seconds and rev at out 2000 when not in gear and when its in gear and im just coasting in gear...the car will decel very very slow...like its still on the gas but not giving it enough to make the car go any faster...anyone experience this problem or know what it is....thanks alot guys
Drew
earthworm's Avatar
Saab Sage!
Has the IAC (idle air control) ever been serviced???
Even if the dealers charge $800 for a major service, they will not touch this - and I fear most will just replace, despite its high cost.
The earthworm
'96 900S, Automatic
jonny72888 jonny72888 is offline
Banned
My Saabs: 1999 9-3 5spd
Drew
i think the car is trying totell you soomething...
go faster!!!
i would oil up the cable and around the TB, also check for kinks in the cable.
Saabohème's Avatar
Saabohème Saabohème is offline
My Saabs: 2008 9-3 SS 2.0 6Spd JZW Stage 1
Yeah it sounds like an air leak, which is what EW was getting at. Not likely that the accelerator pedal is actually sticking. When air is allowed in where it should not be, the revs will stay up and then slowly drop to some high idle point. As EW said, remove the IAC clean and lube it and reinstall. Check the hoses connected to it for cracks. If the IAC service does not fix it, look for a leak in a vac line, for a cracked throttle body transition casting o-ring, or for your throttle plate to not be closing all the way when you are off throttle.
Old 12th August 2007
well the throttle isnt revving anymore.....its all better...i cleaned out the throttle body with some cleaner and now shes idling soo much better...and there is much better throttle response
earthworm's Avatar
Saab Sage!
The correct things have been done - it is not always the IAC...Build up of varnish, dirt, sludge at the throttle plate and in the bore of the throttle body is a bit of a problem..
On the Honda, I'll have to do the same - she is idling too slowly....
The earthworm
'96 900S, Automatic
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
