Factory Saab ""Long-Life"" oil filter - SaabCentral Forums
Old 08-08-07
area51's Avatar
area51 area51 is offline
My Saabs: 1994 Saab 900S - 114k miles
Default Factory Saab ""Long-Life"" oil filter
Anyone know anything about these oil filters? I'm thinking about buying a case of them from Eeuroparts.com
Anyone know what the "long-life" mileage is on these?
Old 08-08-07
earthworm's Avatar
Saab Sage!
BITOG oil filters and the Sticky FAQ on the same.
I use the one size larger Purolater - probably number one or two worldwide. This is changed every 3 to 4 K miles.
I'd change the "long life" filters every 4 to 5K miles.. These Purolators average about $3 to $4 - they are discounted at Pep Boys.
The earthworm
'96 900S, Automatic
Old 08-08-07
Flashheart's Avatar
Flashheart Flashheart is offline
My Saabs: 02 Vrt, 99 9-3, 87 900S, 83 900T & Brits
Hey earthworm...you say you are using one size larger? What # are you using...that sounds like a good idea...
Old 08-08-07
GaryG GaryG is offline
My Saabs: Curently: 06 9-5 Aero & 02 9-3 SE
At one time Saab filters were made by Mann in Germany and they were a very good quality product. Now that GM took over the Saab filters are just rebranded AC Delco. There were some good AC Delco filters at one time but I think that now they just use the commonly available Delco type. It's probably not worth the extra money just to get the SAAB name on your oil filter.
Old 08-08-07
area51's Avatar
Thanks, that's kind of what I was really asking. I use either Napa Gold or Mobil 1 currently.
Old 08-08-07
redrum's Avatar
redrum redrum is offline
My Saabs: 1997 900SE 2.0t
I've always used Purolator Pure One oil filters, relatively inexpensive and easy to find.
Just stay away from Fram filters and you should be fine.
Old 08-08-07
earthworm's Avatar
Saab Sage!
Purolator 20195
But on a GM900S, the filters 20mm added length rubs on the oxygen sensor harness sleeve - no big deal, but I do not like it..
I doubt if there is really much difference of importance between filters.
Funny that Purolators (from PepBoys) are cheaper than Fram - despite Frams so-so reputation. And I think it is wasteful and silly for any manufacturer to have their name on a battery or a filter...99% of the people know better - I think...
The earthworm
'96 900S, Automatic
Old 08-08-07
Flashheart's Avatar
I too only use Pure One filters - based on years of experience in my other cars - just never actually thought to use a bigger one. I would only worry about any internal pressure items....
Old 08-08-07
gurn's Avatar
gurn gurn is offline
My Saabs: 96 900s ragtop;91 900s;92 9000s
I read somewhere the PureOne filters are to restritive.Can cause oil starvation.
"SAAB people are the best." Glenn Beck
Old 09-08-07
That's the reason for going to a larger filter. You get better flow with more filter surface area. Larger filters can hold more "dirt" but this is hopefully not an issue unless you're doing a sludge cleanup.
I use Puro Pure Ones or Motorcraft FL400s which trap smaller particles but are larger than the standard SAAB size and have more filter media.
Old 09-08-07
Flashheart's Avatar
GaryG = are you using the same size listed earlier in this thread too? Or are you using the one PureOne recommends for the Saab?
Old 10-08-07
I use mainly the Motorcraft FL400S filter which is reported to be manufactured by Purolaotor. (Ford doesn't make their own filters just like SAAB!) It has the same relief valve pressure as the SAAB spec filters. Use a little extra insulation around the O2 wire to prevent wear from contact with the filter.
Sometimes I go with the Walmart ST-3600 which is identical in size and is made by Champion Labs. It's one of those new E-core models that have been discussed alot on BITOG forums. I like them so far and haven't had any problems.
Old 10-08-07
earthworm's Avatar
Saab Sage!
This is one of the many things that I do not understand.
Why do the manufactuters specify that their filters be so damn small, and then specify such long OCIs ?
There seems to be plenty of room - Saab could redesign a little and have room enough for a PER-1 filter ( Ford spec , from 40-50 years ago)... even the old PER 17 for the 60s and 70s V4 was rather large.
I think this is a case of bean counters running amuck..
A tiny filter will cost $0.02 to $0.03 per unit less to manufacture and save several grams in weight.. and the knowledgible DIY could be less than 1% of the car owners......
The earthworm
'96 900S, Automatic
Old 10-08-07
jonnyfgroove's Avatar
jonnyfgroove jonnyfgroove is offline
My Saabs: - 96 900SE Coupe - 5spd, 170k
Yeah, if you cut open the stock size filter, the amount of media is dinky. Not saying that it is incapable of filtering just fine, but it still looks wimpy. Here's a pic of a Fram TG3614 (the stock size for our cars) from my friends Tacoma.
Excellent Saab DIY sites:
PMI - Dip - Munki - Michel Briand - Mattias
Old 10-08-07
Flashheart's Avatar
Does anyone know the Saab specs for gpm and pressure relief valve for the NG 900's? I have been searching the forum...to little result.
I did find this in reference to the Saturn 1.9L s series engine....(which I am referencing due to the comments above...even though purolator recommends the 10241)
The saturn stock filter specs are 3 gpm and a 12-15 psi relief valve.
L20064 does not contain a pressure relief valve, while the L/PL20195 use an 8-11 psi relief valve. Given the larger size of the filter though, I don't believe it should run in bypass mode any more often that the stock-size filter.
Purolator oil filter that has the same specs as stock: L25230. This filter flows 3 gpm and comes with a 12-15 psi relief valve, same as stock. Looks like this is the filter spec'd for 2.0L Ford Contours and Escapes
Edit: - I see from Purolators own site that the 20195 has a 12-15 psi relief valve - and is 4.74" length....exactly the same specs as the 25230...weird. I mean according to Purolator there is no spec difference in size and all that for the two. Also the 10241 has a 12-17 psi relief valve....and is of course the shorter 3.36"
