Replacing Shark-fin Antenna - SaabCentral Forums
Old 20th July 2007
Saab_9_3 Saab_9_3 is offline
New Member
Default Replacing Shark-fin Antenna
How do I remove my On-Star/Shark-Fin from my 2004 9-3 to replace it with a "dummy" one?
Old 20th July 2007
pokeyjoe's Avatar
pokeyjoe pokeyjoe is offline
My Saabs: 2000 9-3 Base Coupe
Remove the cover for the CHMSL and pull down the back of the headliner. Why not just leave it?
John
"Where am I going and why am I in this hand basket?"
Old 21st July 2007
epsilon93 epsilon93 is offline
My Saabs: '07 9-3SC 2.0T
His sharkfin may have perished. I had to replace mine too for the same reason. If you don't replace it, water will get in and damage the headliner.
Old 21st July 2007
DavidMorgan's Avatar
DavidMorgan DavidMorgan is offline
My Saabs: My SAAB
Me too, but if this is the case try and get SAAB to do it free. They know there is a problem. Funny when I first reported this problem here everyone was asking how they could "perish". But that is what happens
Old 21st July 2007
Mr.SportCombi Mr.SportCombi is offline
New Member
My Saabs: 9-3 2.0T, 4-cylinder, 210 hp @ 5,500 rpm
Looks like we have similar problems on hand, got to replace my Saab antenna,too..epsilion93 is right, if we don't replace it immediately, we will be inviting further damage...
Saab 9-3 2.0T Sport Combi
4-cylinder
2.0 liter (1,988 cc, 121 cu. in.)
210 hp @ 5,500 rpm
221 lb. ft. @ 2,500 rpm
6-speed manual
Old 21st July 2007
Not when it happens after warranty ends. Saab won't do it for free. That's why they sell replacement parts.
Old 21st July 2007
Acidradio's Avatar
Acidradio Acidradio is offline
My Saabs: 2004 9 Arc
Out of curiosity, does anyone know the part #'s for the dummy antenna and the Onstar/Cellular antenna and how much they cost?
I loved the airplane so much, I had to buy their car!
Old 21st July 2007
pokeyjoe's Avatar
93 06-07 Antenna 4dr/5dr Telephone/Navigation OES 12762120 $ 158.11 Buy Now
93 03-07 Antenna Dummy 4dr/5dr OES 12791659 $ 34.92 Buy Now
thesaabsite.com
John
Old 21st July 2007
My Saabs: My SAAB
I dont really agree. If a part has been proven to be defective then they are liable to replace it... A sharkfin does not suffer any "wear and tear" it was simply made from materials that would not last 3 years of wind and rain!. Insist and make a song and dance about it. Tell them that you have written this up on the biggest internet forum etc...
Old 21st July 2007
pokeyjoe's Avatar
I'm sure the sun does far more damage.
John
Old 21st July 2007
New Member
I am a little intimidated to remove my headliner. Can I get some more details on removing this? Maybe a image or two.
Thanks
Old 22nd July 2007
pokeyjoe's Avatar
I don't think you actually need to remove it. Once you remove the cover for the top stop light, I think there's a plastic button you pop off (like the airbag ones) and then you can pull the cover down enough to see in there.
John
Old 22nd July 2007
New Member
I removed the top stop light cover but could not get the headliner button off. How is this button secured?
Old 22nd July 2007
pokeyjoe's Avatar
Just pull it straight down. if you can't, stick something behind the headliner to pry with.
John
Old 1st August 2007
New Member
SO I now have a new sharkfin on my sweet saab 9-3 aero but now i have a new problem. Every time i turn on the car I have to clear my SID. It tells me that the OnStar has had a malfunction. How can I not have this message come up evrytime the car is started?
Thanks,
Rob
Old 1st August 2007
My Saabs: My SAAB
Thanks,
Rob
Replace the old one... No, sorry I didnt say that..
But you probably need to haveTech II tell your car that you do not have OnStar.
Old 27th May 2008
boyd.lynn boyd.lynn is offline
My Saabs: 2003 9-3 SS 2.0t Black
Thanks,
Rob
Rob,
How did you change your Sharkfin. Mine is cracked and looks like it may start leaking water into the cabin.
Regards
Boyd
Old 27th May 2008
sbl sbl is offline
My Saabs: Formerly, 2003 Saab 9-3 Arc
I removed the OnStar box and installed a MOST loopback connector in its place - no more OnStar error.
Old 27th May 2008
Sorry, I should have been a bit more specific.
My Sharkfin has been looking 'rough' for about a year and yesterday I noticed that it has some large cracks in the rubber. It looks dreadful and I am concerned that water may start to leak into my roof lining which will ruin it.
I don't feel confident about removing the roof lining myself so I need to decide whether to take it to to the Saab dealer to have the sharkfin replaced (at huge expense) or if I can get away with just leaving it. Since it iis a MY03 I can't see Saab offering to replace it for free.
Regards
Boyd
Old 27th May 2008
thomjam's Avatar
thomjam thomjam is offline
interesting.
where is the box and for the uninformed, what is a MOST loopback connector?
thx.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
