serpentine belt tensioner tool?? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Workshop
9000 Workshop 9000 (1985-1998) Technical Forum
Old 11th June 2007
tuner4life tuner4life is offline
My Saabs: 1992 Saab 9000 Turbo, 1995 Honda Civic
Default serpentine belt tensioner tool??
OK. While trying to get the serpentine belt off on the 2.3t, the tensioner is like a little shock absorber, which I had to replace for darn close to $90. But while putting the belt back on, the tensioner was wery hard to compress enough to but the belt back on. So I was forced to rig up a very unsafe and difficult setup involving a hydraulic jack, 2 bricks, a 2x4, and 2 friends (1 larger one sitting on the car to keep in on the jack stand, one jacking, and me risking my hands to try to get the belt on.)
I guess I would like to know if there is a tool to compress this tensioner, and if so where can I get it? I cant seem to find one anywhere on the net.
Old 11th June 2007
yaofeng's Avatar
yaofeng yaofeng is offline
My Saabs: '94 9kcs, 9kcde, '95 9kcse, all turbo
Check the archive. This has been discussed many time before. But it is so elegant its worth repeating. You need a 1/2" drive 18" long breaker bar and a 1/2" drive 19 mm short socket. Assuming you have the passenger side wheel off, the wheel arch removed and the belt loosely and properly routed, stand in front of the car facing the rear. Slip the 19 mm socket onto the tensioner bolt head. Push the bar toward the rear tip pointing up. Exert a steady force onto the bar until the tensioner is compressed so you can slip the last loose part of the belt onto the idler between the alternator and power steering pump. You need to use your right hand to keep the force on the bar and the tensioner and crouch down to use your left hand to slip the belt on the idler.
Takes about 1 minute.
AIM:yaofeng4249
'94 cs, '94cde, '95cse, all turbo and 5 speed all gone,
4 bimmers now '95 525i, '94 540it/6, '01 540it, '03 325i
Old 11th June 2007
Thirsty9000's Avatar
Thirsty9000 Thirsty9000 is offline
My Saabs: `94 9000 CSE auto
Sounds like something I would have tried 3 years ago.... come to think of it, that is something I tried 3 years ago.
Best way to get rid of tailgaters: Use the Turbo!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
