| Saab 9-3 & NG900 Workshop Saab 9-3 & NG900 (1994 to 2002) Technical Forum |
I just purchased a used 97 saab 900s
. How difficult is it to remove a passenger side axle shaft from the transmission?? I have a ripped inner cv and decided to replace with a remanufactured shaft that has both cv with it. When I put it back in , does it just slide in or are there clip of some kind. any sites with pictures for this procedure ?- I cant seem to find a haaynes or chiltons repair book Is it reccomended to use a new axle nut? are ball joints replacable or should I just inject more grease - im afraid I might mess up the ball joint during removal I get a good response from the saab 900 classic forum but just relized that I have a 900ng (1997 900s) so im reposting Thanks in advance - im a occcasional side yard mechanic that usually gets himself in too deep so any advise will only help! Any help or guidance would be much appreciated!! Thanks, snick |
| Sponsored Links | ||
Advertisement | ||
http://photo.platonoff.com/Auto/2005...Inner_CV_Boot/
HTH More to come, I used to do this with the now old ones; the boots (gaiters) were good for several years. About 10 days ago I changed one side on the Honda - this was very, very easy. The new axle , from AutoZone, come with a new axle not... I have yet to tackle the right side of the newer Saabs, the last one was a '84 - outer boot only, easier and far less expensive than the Honda.. On the joint boot, yes !, inject grease as necessary. I use the "pickle fork", with good results- seldom tear any boots..
The earthworm '96 900S, Automatic Those who think in the past will have no future. 173K miles in the good ole USA Last edited by earthworm; 06-06-07 at 12:09 AM. |
Granted, I'm a retard, but I removed the lower control arm from the subframe to swivel the hub out. Very easy. The inner driver has a snap ring that you can overcome without much effort.
The shaft on my '97 900 was seized onto the jackshaft, I ended up using a pickle fork wedged between the jackshaft housing and the cv shaft itself- and lots of hammering, and it finally came off the shaft. It was rough.
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
