clutch reservior - SaabCentral Forums
Old 26th May 2007
saabrider saabrider is offline
My Saabs: 1983 900 turbo 3 door
Default clutch reservior
Hello, Can anyone tell me where the clutch reservior is for the 900 turbo, 83, 2.0 8 valve? The auto parts store told my friend that there is no fluid to add but my manual says there is a reservior to add to but not where the reservior is. Is it clutch fluid that is used? Mike
Old 27th May 2007
ejenner's Avatar
ejenner ejenner is offline
Banned
My Saabs: 900 Carlsson, 99t, 99 T16, 900 t16 vert
the clutch fluid resivor is the same as the brake fluid resivor. If you look underneath the brake fluid resivor you'll see a little nipple with a hose connected to it. The hose runs from the fluid resivor down the the clutch master cylinder... but I'll bet, if you're having a clutch problem, that topping up the fluid isn't going to fix it. You would at least.. need to bleed the clutch circuit but that still won't fix a broken seal at either master or slave cylinder. Try what you like in the meantime but I suggest you be brave and work to narrow down to either slave or master and then replace the appropriate component. To bleed the clutch circuit you need to use a pressure bleeder. This is due to the design of the system and you can't bleed it any other way. Pressure bleeders don't cost much but that's what you'll need if you don't already have one.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
