Help! - SaabCentral Forums
Old 26-05-07
Teambaylagoon's Avatar
Teambaylagoon Teambaylagoon is offline
My Saabs: 2007 Saab 9-3 Aero
Exclamation Help!
I bought new H7 bulbs for my 2007 Aero, installed them and they dont work, so I figured ok bad bulbs, well I reinstall the originals and now they dont work!
What the heck is going on?!
Old 26-05-07
SnowgodCCR SnowgodCCR is offline
My Saabs: JK Rubicon..HAD an '04 9-3 Aero-STUPIDME
Ok. Dumb question: are your lights on?
Next, did you install them properly?
Next, I have no idea. I'd take it to the dealer...bulbs are included under warranty anyway...and they'll likely install your new bulbs at no charge (that's what I always did I have big ham hands that made it really hard to get the bulbs seated properly) for you. Good luck!
Old 26-05-07
dept2 dept2 is offline
My Saabs: 2003 9-3 SS Vector
I agree to snowgodCCR's opinion.
Go to dealership. then, check it and change it.
It can covers by factory warranty.
Old 26-05-07
JonV JonV is offline
Saabista
My Saabs: 03 Vector
Any SID messages? Check your Fuses?
Old 26-05-07
Yea, Front headlight failure, I looked in the manual for fuses, I did see any associated with headlights other than the levelling mechanism
Old 27-05-07
VectorDan's Avatar
VectorDan VectorDan is offline
My Saabs: 2003 9-3SS 2.0t Vector BSR Stage 3
Fuse 24 it seems... If this fuse is still OK then it's likely you'll have to get that trouble code cleared before they'll work again (it's one of the steps in the workshop manual when replacing the H7 bulbs - to clear any trouble codes), unfortunately...
Edit: Fuse 26 changed to 24
Old 27-05-07
gjdavies's Avatar
gjdavies gjdavies is offline
My Saabs: Saab 9-3CV Aero TTiD 180
Are you replacing the right bulb?
It could be you are replacing the main beam bulb, rather than the one behind the projector lens.
A clue is, if you can see the bulb you are replacing clearly, it's the main beam (Full/Flash) rather than the normal headlight behind the projector.
Just a thought.
...just give me ten minutes, look at the moon or something...
Old 27-05-07
I have the Xenon bulbs, and I have H7 low beams, that come on with the parking lights, these are the ones I was trying to replace. I wasnt touching the Xenon headlamps they still work fine. I have 1 accent light 1 H7 1 Xenon and 1 turn signal bulb in my headlamps, I replaced the accents with LED bright whites, (which work fine aside from the blinking LED when not on) but the H7's wont work, I know none of the wiring is damaged, Ive checked Fuse 16 and 26 in the engine fuse panel (which were for front low beams) both are fine. Im going to guess it has something to do with the aforementioned code clearing necessity, I just dont want the dealer to give me shiat about changing my bulbs.
These are the bulbs I can see in the headlamp, not the ones behind the projector, didnt touch those. I replaced an H7 with an H7. Not that it makes a difference but I also changed my H3 foglight bulbs, and they work fine, its just these that dont.
(not my car just a pic I borrowed)
Old 27-05-07
Xeo01 Xeo01 is offline
My Saabs: 9³ JZW Stg4 16T Custom
I have the same problem. Except mine have never worked. The bulbs work fine. Just not in the Saab. I was told these lights were disabled in the U.S.. They are actually highbeams that come on with the Xenon Highbeams. I don't now if this is true or not. It just seems weird to have bulbs in there when you can't use them.
Old 27-05-07
Well mine definately worked, then I took them out and replaced them and now they dont work, and neither do the factory bulbs now when I put them back in. Ill hit up the dealer Tuesday, see what they say.
Old 27-05-07
Saabista
My Saabs: 03 Vector
The H7 Bulb is your High Beam and for Flashing....the Xenon (DS2) is your low beam. The Parking/City light is a 5W5, that and the Xenon should be on when your Normal (No DRL's Disabled). The H7 will come on when you hit the Highs or Flash.
Put resistor packs on your LED's and they will stop flashing.
Old 27-05-07
Ok now Im really confused.
Ok after I had my DRL's de-activated, and before I changed anything, these lights would be on if I had my "parking" or headlights on, now they wont come on either way.....HOWEVER, I can put my brights on and they work, but they wont remain on like the originally did w/o having the brights activated, and my SID still says Right/Left Front Position Headlight failure.
Old 28-05-07
In my case, I couldn't use the high beam and fog light after I had installed aftermarket HID and changed Tech II option..
But, I'm satisfied because HID light is good enough to flash on the road at the night..
Old 28-05-07
Saabista
My Saabs: 03 Vector
If your DRL's were deactivated...no lights would be on when you start the car with the Light switch offf, the next position would give you City Lights(w5w), and the third would give you the xenons(DS2), the city lights remain on. The H-7s' are only for Brights and Flashing. I actually think it best you have a Service dept check it out....if your relationship is good they may just sort it out at no charge...
Old 28-05-07
Saabista
My Saabs: 03 Vector
Do you have Xenon or Bi-Xenon....with BiXenon a shutter raises behind the Projector lens which becomes the High Beam, not the H7.
Old 29-05-07
I have Bi Xenon and have the shutter open when I flash someone or use my high beams. Still don't know why my H7 Halogen don't work. Something tells me I need to disable DRL's.
