Originally Posted by Fan-TC
Right.
Firstly, I am now in a 96 9000 CD LPT. I dont love it anywhere as much as my old c900 aero but its good, cheap (extremely) transport.
I have driven it stock for about 3 weeks. Now i have decided nuts too that so I have put a full turbo computer in it and a turbosmart 2 stage boost controller.
My issue is that i am having heaps of trouble getting the turbo to make extra boost. Even with the bleed valve fully open I cannot get more than 0.5 bar (from 0.4 bar stock). I have played around with it, wound the wastegate actuator rod in. But no matter what i cannot get higher boost. I have disconnected the wastegate line just for testing and it definitely will make 1+ bar without a wastegate so I am definitely having wastegate issues. (yes i was careful not to overboost with the wastgete disconnected)
I need to know what the best option is to fix these rediculously soft wastegate actuators is?
thanks for the help.
Karl
My previous car was a 96 9000 LPT, which I converted to FPT with a BSR stage 1 ECU, as part of the upgrade, this also required fitting a Saab Boost Pressure Valve, as the standard LPT is not fitted with one of these. Have you got this BPV fitted? If not you will not be able to make full pressure...
I also found that to get the power that I should be getting I needed to upgrade the actuator to a Forge unit, once all this was done the car was transformed and easily made 1.2 + Bar boost and in excess of 220 BHp
