Failed MOT -Lamda reading - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 23-05-07
problemsaabman problemsaabman is offline
New Member
My Saabs: 9000 CSE 1993
Default Failed MOT -Lamda reading
Hi,
My Dad passed his Saab 9000 CSE on to me last year and I've just put it in for it's MOT. There were a couple of minor things but the main thing is that its failed on the lamda reading. The garage say they've checked a few obvious areas like hole in the exhaust but has said they 'wouldn't know where to start'. It's an old car and to be honest I don't know much at all about cars. I don't want to spend loads on it. However, it would be a shame to get rid of it if its a problem that could be easily fixed.
Ideas, suggestions would be appreciated.
Cheers
Old 23-05-07
Jim Mesthene Jim Mesthene is offline
I don't know much about the foreign cars you drive over there, but I know a hole in the exhaust will affect the Lambda.
Fix the exhaust, get it good and hot on the highway, test it again.
Corporations are people! If you prick them, do they not bleed? If you tickle them, do they not laugh? If you poison them, do they not die?
Old 23-05-07
UK9K's Avatar
UK9K UK9K is offline
My Saabs: HKS powered 92,9K CSE 2.3A T
Hey problem, if the exhaust is NOT blowing anywhere, then you could try go down the scrappy, look for a lambda sensor from another 9000. Make sure you check how many wires/colors your has, and get the same one. Won't cost much, and if it works and passes the MOT, your sorted.
Old 24-05-07
boxman's Avatar
boxman boxman is offline
My Saabs: 9-3 SS Aero TTiD + 9-3 SV Aero
if changing the lambda sensor doesnt fix the prob' then you could be looking at a new cat, you could remove it and look inside to see if it is either blockes or has bits missing
Old 24-05-07
New Member
Hi All,
Thanks for the replies. Problem is I don't have a clue with cars and wouldn't even know what or where these parts are on the engine. Anyone know someone in South London, I'm in Streatham, who won't charge a fortune and might be able to sort it?
Thanks again for your input.
Steve
