Bonnet catch - SaabCentral Forums
Old 19th May 2007
Jezzadee's Avatar
Jezzadee Jezzadee is offline
My Saabs: Yamaha FZ6 Fazer
Default Bonnet catch
Now and again I indulge in a bit of 'spirited driving', as you do. It's bumpy roads here, with occasional take-offs over low bridges and lots of potholes. Lately every time I hit a big bump, the bonnet catch pops up. Happened twice today, once when I was overtaking someone, which was inconvenient.
On the underside of the bonnet there are two circular rubber guides, and I've rotated these pointing due forwards (they were 45 previously), which seems to help. Is there some adjustment to the main metal catch I can make to stop this happening, because looking at it I can't see how I could adjust it at all.
Go Dutch
Old 19th May 2007
grif900's Avatar
grif900 grif900 is offline
My Saabs: 1988 900 SPG
i soak mine with pb blaster when they act up.never had to adjust one ever. sonds like the main catch is not closing all the way.
Old 19th May 2007
Jim Mesthene's Avatar
Jim Mesthene Jim Mesthene is offline
Saabista
My Saabs: Wife's 9-3
Remove the grille
Loosen the 2 6mm screws that hold the latch in place
Push the hood pin down on the hood latch, using the taper to center it
Tighten the latch in place
Adjust the cable if needed
Adjust the pin length with washers/spacers if needed
Adjust the rubber stops to just barely contact the hood when latched
Grease the latch and pin
Oil the safety catch pivot and spring
Refit grille
The fact that there's a Highway to Hell and only a Stairway to Heaven says a lot about anticipated traffic numbers...
Old 20th May 2007
Jezzadee's Avatar
Nice one Jim, I'll have a go at that this morning.
Go Dutch
Old 20th May 2007
RedRag's Avatar
RedRag RedRag is offline
My Saabs: 900i Convertible 16v
Hi Jezzadee,
Sorry if I'm late with this info, and you've already tried the other suggestions...
My car was doing exactly the same thing, for months and months, I was having to stop at least 5 times during my daily commute towards the end before fixing this.
What I did, after going down the remove grill and inspect mechanism route, what to turn the pin (on the bonnet), a 1/4 turn. The "head" of the pin had got very worn on the edges that engage the catch. Once the pin was slightly rotated, the catching action of the mechanism was restored. The pin is still in place, (i.e. it's not losened enough for it move of it's own accord), and I've now done about 1,500 miles without a single pop!
Shaved 20 minuites off the commute time too!
Mark
Red Rag
Old 20th May 2007
Jezzadee's Avatar
Cheers for the info Mark - I undid the whole pin today, cleaned it up and reassembled, so hopefully that's done it. If not I'll try giving it a 1/4 turn.
Go Dutch
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
