Ok, I've been looking at getting new wheels for the SPG. Its a 1989.
I've been looking at different wheels, and somewhere I saw that my car needs a 4x108 bolt pattern. But then I saw other people talking about their wheels and a 4x114 pattern. Which pattern is required by my car? the 4x108 or the 4x114? Also, I was searching for the proper offset, and saw I should bee looking for an offset of 35mm. Is this right? I'm looking for 17" wheels, possibly even 18" if I can get them to fit without rubbing.
1997 Saab 900 SE - JSP Stage5 - Needs bigger turbo 1994 Saab 900 Airflow Vert - The topless beauty 1989 Saab 900 SPG #1 - awaiting re-assembly, soon to be megasquirting & eating transmissions 1989 Saab 900 SPG #2 - Crashed, now another "parts car" 1988 Saab 900 Turbo - The rusty "parts car" 1983 Saab 900 8valve - Now with TURBO! |
| Sponsored Links | ||
Advertisement | ||
Your stock wheels are 4x108, 15x5.5 in and 45 mm offset.
Factory 6 inch rims on the 9K were 33 mm offset. The offset depends on the width of the wheel fitted.
So a set like these: http://cgi.ebay.com/ebaymotors/17-AD...QQcmdZViewItem
Would fit with proper tires?
Isn't it extraordinary that in 192,652 posts in the 900 forums, this is the first time we've ever talked about wheel bolt patterns?
The path of my life is strewn with cowpats from the devil's own satanic herd Last edited by Matthew; 09-07-07 at 07:12 PM. |
The faster you go, the more you see. |
i do belive bolt pattern and wheel offset have been brought up in a few of the 88trillion tire threads.
those borbet wheels look very nice to me. |
That the FAQ doesn't hand the answer to you on a plate just means you have to put in a bit more effort.
The path of my life is strewn with cowpats from the devil's own satanic herd |
Well, obviously since it's discussed so often, and there are so many threads, it might be a good idea to sticky a thread, and/or add a link to one in the FAQ. Since 45 minutes of searching did not provide me with my answer and thus I had to start yet another wheel thread.
Less than three minutes of searching came up with these threads:
http://www.saabcentral.com/forums/showthread.php?t=889 http://www.saabcentral.com/forums/sh...ad.php?t=23219 http://www.saabcentral.com/forums/sh...ad.php?t=37189 http://www.saabcentral.com/forums/sh...ad.php?t=26195 http://www.saabcentral.com/forums/sh...ad.php?t=21474 There were at least two dozen more listed, all of which contained information answering your question.
The following terms are too general and were excluded from your search: bolt, pattern
Oh dear, I fear it's all been said before.
To avoid this sort of tedium in future, we must do the only sane thing - ban new threads. After all, if you can't find the answer to any question in search then you're simply not looking hard enough. It's been nice chatting, now go away, all of you. |
People like people who help themselves. Nothing reasonable about suggesting people should make the effort to find the answer for themselves, instead of offloading that effort onto others.
Anyhoo back to the tired old topic. amish i imagine you're looking at 7" rims? If the standard 5.5s are 45mm offset then that means you want an offset of 45mm minus an inch and a half, i.e 45-37 = 8mm offset? That doesn't look right. |
I just went through this wheel thing after converting my brakes to '88+ (eg: later hubs came w/these brakes front & back). I didn't know squat about wheels... PCD, wheel widths and such was all greek to me. There's also RONAL SAAB wheels. If you poke around there site you'll find a lot of useful (at least for me) wheel information. They also have some (relatively) affordable discontinued wheels for c900 (+/- $175 per). As it turned out, I got lucky. I found 4 of these at local U-PULL yard for $9.50 per... a little bit of curb rash on the bead surface, but not bad. 1 wheel had maybe a 1/16 in. deep "scratch" near the middle about 1/2 in. long. I found a wheel refinisher in El Paso that comes recomended: I shipped 'em off to him for $125 per. FWIW, I originally preferred my previous wheels appearance. But those things had a deep, recessed groove just inside the perimeter which ran around circumferance of wheel and was a PITA to clean. The newer ones don't have that, and are far easier to clean. Good luck w/your wheel search. |
8mm offset? That doesn't sound right.
I'm thinking about getting a set of Enkei's or BBS RK style wheels.
...Unless 900t is right and the standard offset is +45, in which case the optimal offset for 7-inchers would be +25. I think. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
