| Saab 9-3 & NG900 Workshop Saab 9-3 & NG900 (1994 to 2002) Technical Forum |
| Sponsored Links | ||
Advertisement | ||
What did the whine sound like?
whiiiinnneee
no actually we thought it was a tensioner of something at first. It wasn't super high-pitched or super low-pitched. I'll try to record it. |
Is it a bit like a super charger? Mine makes a sound a bit like a super charger at low rpms and when the motor is cold. I haven't really diagnosed the problem however.
I checked the top end for sludge and it didn't look too bad. I'm going to wait for summer to drop the oil pan. |
I think it is a bit like a supercharger actually.
I thought the 1999's wern't affected? |
What you could be hearing now is turbo whine from the sludge clogging/coking the bearings in the TD04. Is the noise varied as you get on and off the throttle?
Do you ever get any smoke or anything from the tail pipe? My guess is that you will be rebuilding the turbo soon unfortunatly. |
You'll need to buy a new turbo at least by then if you're lucky or a new engine if you're not. Sludge causes oil strarvation. You need to fix that ASAP That's if it's a sludge issue. Other causes for the whining is a bad tensioner pulley or water pump, steering pump or alternator. They all have bearings and when they go bad they whine too. |
The WP, alternator, PS bearings can be eliminated by releasing the belt tension.
Maybe this whine is from the turbo bearings. Is it possible to use a hearing device here ? I hate to guess. But if the noise is in the engine and you plan to rebuild; why not rebuild the turbo??
The earthworm '96 900S, Automatic Those who think in the past will have no future. 173K miles in the good ole USA |
My solution for the whine in the Datsun was redline manual trans fluid. I think I'll add that to my things to do for the summer in the Saab Last edited by stamonkey; 07-05-07 at 01:49 PM. |
mine case sounds similar to lms', I think. If I can, I will record sound or even video. I ALMOST hope I need to rebuild the turbo, because I would get an 18T then!! but I want the hardtop tuned, not the vert..much better handler!
Are you getting any smoke at any time?? |
no smoke as of now. I'll see if my cell phone can capture decent sound, if not I'll upload a giant video camera file.
Ok, I have determined in my drive back from the office, with the windows down and my head hanging out the window, that the whine only occurs in second gear at low speeds and low rpms. Once the car has been driven for a bit, the noise stops entirely. The whine is very faint and can't be heard with the windows up. I am at 98k right now and have driven the car about 25k since I have owned. I have changed my oil with full synthetic every 3k miles, and changed the pcv about 10k ago. I also inspected the top end for sludge when I changed the pcv (and before I bought it). I burn no oil, and get decent gas mileage. Sooooo, I am sticking with my guess of a noisy transmission. In a month, when I head home for 6 weeks, I'll be dropping the oil pan, changing the trans fluid, and HOPEFULLY adding a Wazee pulley (if they are ever back in stock
****. My Dad pulled the va;ve cover off the other day and its pretty bad. Luckily we havn't heard a tick or knock, but I assume that is the next step in the engine's demise. There is a lot of sludge up there, even on the cams and covering some of the bolts completely. Any advice? I want to tear the motor apart.
Got any pictures?
Sorry to hear about it |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
