Spark plugs--easy to change? - SaabCentral Forums
Old 30th April 2007
web-betty's Avatar
web-betty web-betty is offline
My Saabs: 2005 9-3 Arc Convertible
Default Spark plugs--easy to change?
I did a search on this and came up with a gazillion threads. So, being the lazy (or busy, take your pick) girl that I am, I decided I'd just ask. My CEL has been radomly throwing the p1312 code since Sept. (hopefully no new codes have crept in). I was given advice by many helpful people in this forum that mainly came down to "it's probably the DIC and/or spark plugs." I called a dealer and was told that the DIC has already been replaced for the recall, so I'm hoping that some new plugs will do the trick.
I love my mechanic and he loves me (of course he does, at $80 an hour ). I would like to try and avoid paying for 1 1/2 hours of labor to change the plugs--he quoted me around $160 for the work. From what I've read, the spark plugs are easy to replace.
1) Please tell me this is true, and is there a resource I can use to get this done? Detailed instructions and diagrams are encouraged
2) Please tell me exactly what plugs I need so I can order them online.
Thank you in advance to all of the awesome people who respond--this community has taken the "scare" out of owning this car. I've only had it since August and am petrified it's going to turn into Mr. Hyde--I've already had several issues.
Old 30th April 2007
eckyboy eckyboy is offline
My Saabs: 1995 NG900 Turbo
4 screws take the DI off and unplug the lead from the end of it.A deep socket or plug socket(17mm I think) removes the 4 plugs. Replace and remember to only tighten about 1/4 turn to seat them. Replace DI and push in the lead and hey presto. Takes about 10mins total(less for an expert which I'm not)
ps-you have been quoted an outrageous price by the way, Should be more like 10 dollars.
Saab NG900 turbo
Old 30th April 2007
Tried to edit as forgot to put link in so here it is for plugs - you may get cheaper on your side of the Atlantic but at least this will give you the part numbers.
http://www.elkparts.com/index.php
Saab NG900 turbo
Old 30th April 2007
earthworm's Avatar
Saab Sage!
IF for plugs only, 0.5(1/2 an hour) should be sufficient.
More than that, then something is wrong..
In my time, this was a 15 minute task, an easy 15 minutes...even for a VW type four....
The earthworm
'96 900S, Automatic
Old 30th April 2007
Old Goat's Avatar
Old Goat Old Goat is offline
My Saabs: 1997 900 se turbo
This is an easy job to do. If you are planning on doing it yourself, you picked a real good one. Just make sure to get the right plugs, check the gap, and the rest is easy as Eckyboy had described.
An hour and a half is way too long, even with lunch thrown in. Are you sure thats all they were doing?
Hey! Who you calling OLD?
Old 30th April 2007
bkrell's Avatar
bkrell bkrell is offline
My Saabs: gone: '01 9-5 2.3t, 1997 900 SE turbo
Yep, just buy one of those plug gappers next to the cash register at the autoparts stop to check the gap. Otherwise, it's four screws and then you need a deep sided socket to fit over the plugs.
Old 30th April 2007
G96nt's Avatar
G96nt G96nt is offline
My Saabs: 99 9-3: sold. 95 SEt: sold. '00 GF
it's a 16mm socket, or 5/8" plug socket (has rubber inside to grip plugs)
like stated... 4 hex screws (you have the torx driver in your spare-tire took kit)
then just remove the plugs.
gap the new ones to .038" and tighten 'em back down hand tight, and then 90-degrees past there.
that's all.
Craig R.
'00 Gary Fisher
Goin' fast with class.
Old 3rd May 2007
web-betty's Avatar
eckyboy...can you re-do the link? It's not complete
Old 4th May 2007
ZinXin ZinXin is offline
My Saabs: 9-3se 2000
yeah I'd love a link to some nice spark plugs too
Old 4th May 2007
web-betty's Avatar
Default What kind of plugs?
If anyone can point me to a specific spark plug: manufacturer, part number, etc., I'm actually going to attempt to do this myself. A google search has provided mixed results when looking for "saab spark plug." It came back with different sites, showing different plugs. I want to make sure I get it right the first time
Old 4th May 2007
NahumCC's Avatar
NahumCC NahumCC is offline
My Saabs: 1999 9-3 SE, 2006 9-3 Aero Sport Combi
http://eeuroparts.com/productdetail....ts=1&code=6398
Go there and order four. That link goes right to the specific plug you need.
1999 Stage 3 9-3 SE for sale
2013 FR-S
Old 4th May 2007
earthworm's Avatar
Saab Sage!
Best to use the owner's manual recommended plug..The turbo models take their own, it must be an "R" (resistor plug)..
http://www.geocities.com/ng900set/IDM/IDM.html
We probably have too many threads on this subject..
Use our search.
The earthworm
'96 900S, Automatic
Old 21st May 2007
web-betty's Avatar
that's all.
Ok, I'm getting ready to do this How do I check/adjust the gap if need be, and how do I confirm that .38" is correct for my vehicle? I hate to second guess G96nt, but I want to make sure I get this right the first time.
Old 21st May 2007
earthworm's Avatar
Saab Sage!
90 degrees past hand tight !!
NO !!
Both the male and female threads must be clean and fee of rust and burrs - most new plugs and fairly new cars need little work in this area.
Apply a light dab of anti-seize on the threads; carefully start the plug by hand...
Use a torque wrench set at 18 to 20 ft lbs to finish..
Set the electrode gap (0.039" - turbo chaged 900ng) to the spec in the manual using a wire guage(more accurate than a feeler guage, and easier)..
Double check the specs and inspect every step - this is time well spent..
The earthworm
'96 900S, Automatic
Old 21st May 2007
web-betty's Avatar
They're in
I figured out just how easy using the gapper was. They came shipped at .039" so that was nice.
Two questions:
1) the plugs I took out were gapped at .035"--can the gap change over time, or were the old ones just gapped wrong?
2) could this difference in the gap size cause the codes my CEL is throwing (p1312 and p1334--if I remember them correctly).
Old 21st May 2007
earthworm's Avatar
Saab Sage!
They may very well have been mis-gapped...Erosion will cause the gap to increase..a reason to regap every 10 to 15K..
IMO, a rather small mis-gap should not cause a CEL...
The earthworm
'96 900S, Automatic
Old 21st May 2007
G96nt's Avatar
earth...
you're wrong.
NGK plugs have crush-washers, which make them TTY.
hand-tighten, and then 90-degrees.
if you're re-installing NGK plugs, they require 35lb/ft
This is off the top of my head....I suppose I could check NGK.com for the "troof"
maybe I'll prove myself wrong.
for the sake of humilty...
I was wrong. I left my original answer up, though
here's the chart. we have 14mm plugs.
(I'm used to 16mm in DSM's)
http://www.ngk.com/charglossary.asp?...orque+settings
it's 18-21lb/ft
however, I'm 90% certain that if you go 90-degrees past hand-tight, you'll have your 18-20lb/ft.
Craig R.
'00 Gary Fisher
Old 21st May 2007
earthworm's Avatar
Saab Sage!
Well, the crush washers, in a way ,make the ft lb torque redundent..
Its been years since I have installed new plugs... I do detest overtightening things... so, I will have to experiment - the Honda may be due for new ones... as should the '97 Saab 900SE(married daughter's ride).
The earthworm
'96 900S, Automatic
Old 22nd May 2007
Saabohème's Avatar
Saabohème Saabohème is online now
My Saabs: 2008 9-3 SS 2.0 6Spd JZW Stage 1
Yeah - overtightening steel threaded plugs in an aluminum head can get dodgy. I think of the torque spec for plugs more as the way to prevent overtightening rather than as a method of making sure they are tight enough. Anyone else here ever try to re-tap plug threads in the aluminum head of a Lancia? One thing is for certain: you will never worry if you use the torque wrench. And a man can never have too many torque wrenches. And using crush washers and torque wrenches is the belt and suspenders technique of the cautious shade-tree mechanic.
Old 30th June 2007
web-betty's Avatar
I finally got my spark plugs changed, and yes, I did it myself! Cost under $50 for the plugs so I saved myself $80 in labor. Took care of the CEL so I'm psyched.
Thanks for everyone's help on this post!
Melissa
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
