Brake bleeding psi? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-5 Mk.I, 1998-2009 > Saab 9-5 Workshop
Saab 9-5 Workshop Saab 9-5 Workshop (1997 to 2010) Technical Forum
Old 24-07-12
05Aero21's Avatar
05Aero21 05Aero21 is offline
My Saabs: Steel Grey 05 Aero automatic
Default Brake bleeding psi?
Going to bleed my brakes......getting the Motive Black Label bleeder.What psi should I be at when priming the bleeder? I don't want to crack the master cylinder w/too much pressure. Is 10-15 psi decent? I've read around people setting it at 20. Getting the ATE Super Blue fluid so I can see the change to new better.
Looks like an easy DIY. Have the proper wheel to wheel configuation down, and never let the MC run dry. Any other tips welcome.
Women have the uncanny talent of asking a question and making a statement at the same time:
"Your going to do that today right?"
Not that there is anything wrong w/that.
Old 24-07-12
Norm95 Norm95 is offline
My Saabs: 9-5 JZW lll 44 mpg, 9-5 SC stg IV 39 mpg
Right foot pedal pressure is all you need. Open the bleeder screw, pump, last pump hold pedal down with broom or shovel, tighten bleeder screw, and your done. Pump 25 times for the rear 15 times for the front.
Old 24-07-12
MI-Roger MI-Roger is offline
My Saabs: 2008 9-5 Aero Sedan, 2006 9-3SC 2.0T
The instructions that came with my Power Bleeder state to use 10psi. I didn't find these instructions until after I bled my brakes, where in I used mid-scale on the pressure gage or 15 psi. No subsequent brake problems having used 15 psi.
Other tip: Buy the swivel hose adapter for the Power Bleeder. The standard hose without a built-in swivel is a real PITA to connect and disconnect. Maybe your "Black Label" version comes equipped with the swivel.
2008 9-5 Aero Sedan
2006 9-3SC 2.0T
2000 9-5 lpt Sedan, Retired at 318,000 miles
Old 24-07-12
blackls1ttop blackls1ttop is offline
My Saabs: 01 9-5 SE 95k (parting out please pm me)
crack the master cylinder??
the brake system runs on a couple thousand psi with the power booster being used.
Old 24-07-12
05Aero21's Avatar
I just read that somewhere online as I was researching how to do this w/the power bleeder.......not too pressurize it too much.
Old 24-07-12
05Aero21's Avatar
I think it comes w/it, but I'll make sure when I get it.
Old 24-07-12
05Aero21's Avatar
I'm sure that method works.........I know from the old school days. The only problem is you have to constantly look to see if your running your MC dry.
Old 17-01-13
a3holerman a3holerman is offline
My Saabs: 96 Aero standard 260k 2006 9-5 Aero
Another thought and it did happen to me. If you use the pump to the floor method you run the real risk of damaging the master cylinder. The reason being is that the plunger with the rubber seal is now going into and area of the cylinder it never get to and there may be some rust/corrosion there and it could ruin the seal.
Tom
Old 17-01-13
demosan demosan is offline
My Saabs: 2004 9-3 AERO(sold) 2006 9-5
I use the motive bleeder as well ( it is fantastic tool and makes it a simple one person job) and use 15psi with no problems in any of my cars.
Good Luck demosan
Old 17-01-13
helmetvonthrob helmetvonthrob is offline
My Saabs: = 2003 Aero x2 =
Use the minimum pressure to get the fluid moving!
Brake Bleeding jakejm79 Saab 9-3 & NG900 Workshop 9 02-09-11 10:30 PM
Brake bleeding fun supremedalek Classic Saab 900 Workshop 1 14-09-09 10:47 AM
brake bleeding RHD justyjust Saab 9-5 Workshop 2 16-12-08 02:08 AM
brake bleeding KnoxSaab Saab 9-3 & NG900 Workshop 7 16-06-06 10:37 AM
Bleeding brake system and changing brake pads firstime Classic Saab 900 Workshop 2 20-10-05 08:46 PM
