What size are the torx bolts that hold the ac compressor on?
Also when i move one of the hoses from the ac, theres a hissing noise that comes from one of the fittings. How do i depressurize the system an eventual complete removal of the ac system? And is there any chance that the compressor wil seize up as its unused outside of the car? Thanks,
The compressor mounting bolts are 6mm hex, not Torx.
You're right about the twin "combo hose"--if you hear escaping gas, it's bad. A new one is not that much money from www.eeuroparts.com
Depressurizing the system should only be done by a pro--it's illegal for you or I to do it, so I'm afraid I can't publicly give details of any quick-and-dirty DIY method :nono;
Unfortunately, you'd have to remove the entire AC system in one piece if you wanted to keep it pressurized!
This means pulling simultaneously the evaporator core in the firewall, the condenser in front of the rad, the compressor, the receiver-dryer, and all lines and hoses. Can't be done without disconnecting at least some of the lines/hoses, which of course would constitute an illegal evacuation of the system...
I'd suggest keeping the system as is, and converting it to the newer R-134a refrigerant; I did this to my '88 last year, and the kit was only $30
If i were to keep it the ac system, there is actually a newer refrigerant out there, where you dont need to do the conversion to r134a. But im pretty certain im going to get rid of it, so its going to have to be depressurized.
-Alex
Related Threads
SaabCentral Forums
3M posts
119.1K members
Since 2001
