First, I would like to declare myself an idiot. After heavy rains I drove through a puddle I "thought" wasn't that deep. I got through it fine, drove about 10 miles shut the car off for about 30 minutes, got back into the car and drove 10 miles, back through the same puddle (double stupidity) about another 5,000 feet and parked the car for 3 hours. When I went to start the car I had power, an SID message stating "Traction Control Failure" and "Stability Control Failure" my gas indicator showed zero (when i parked the car it read 3/4 full, there was no gasoline on the ground) and the engine did nothing, no noise from the starter, all I could hear was the auto leveling headlight check and a relay clicking by my left knee. I tried putting the car into and out of gear (automatic), tried restarting and same thing, I disconnected the battery, reconnected the battery and same thing. Had towed to a mechanic (not a dealership) where they tested the starter, charging system, fuses, check engine for hydro-lock, battery and found nothing. Before I drag this to a dealership I thought I might try to save myself the $120/hr. and figure this out myself with the help of some of you. Does this ring a bell to any, or are there any good suggestions (outside of rolling into a lake)? Thank you.
Minus the water, I had a similar thing happen to my car one morning last winter. Traction control Failure, Stability control failure, ABS failure, no gas guage. Also, the speedometer wasn't working. I drove to work (3 miles). When I got there I shut the car off and turned it back on. Everything powered up just fine. I have not had any problems like that since then.
When ever I've reset the ECU I've disconnected the battery overnight, sorry I cant be much help but it doesn't sound like you got water in your engine.
I think its definitely an electronic problem if the starter isn't cranking, is it an automatic or manual if you can get it to accessories and its manual I would try and push start it.
There was water in the air filter, but no sign of it anywhere past the filter. It has been sitting since Friday, unfortunately it has been damp and snowy/rainy here since Sunday.
Yes it is stock, no aftermarket parts anywhere on the car. No modification to the suspension so stock height as well. The puddle that I estimated to be roughly 3" in depth was probably closer to 8". This might be a reach but is it possible that the fuel sending unit was damaged? I am not sure of its location, but maybe that would explain why the fuel gauge reads zero and why the engine wont start? The mechanic feels it is an electronic safety feature that has crippled the car, but I wouldn't know where to start, I have been browsing through the WIS but I have extremely limited knowledge of any type of automotive/electronic system.
I just hope that you didn't hydrolock your ride. Let's just hope it's something electric. I'm sure your mechanic will figure it out and have it fixed for you.
-check the hydo-unit ABS/also, control unit engine connectors for waterproof. see is there is water in or terminals darked by water short circuit or dielectric resistance.
-check the hydo-unit ASB/also, control unit engine connectors for waterproof. see is there is water in or terminals darked by water short circuit or dielectric resistance.
Is this a silver block with two black caps located between the battery and engine block towards the back of the engine bay? if so I believe there was water on top of this but I attributed it to splashing back from driving through the puddle.... when I get home I will post an image from the WIS of what I am referencing for comparison. If we can confirm this to be the issue what further steps would need to be taken, or should we hold off on getting into this more until confirmation has taken place?
-I appreciate all the help that everyone has been so far, and I appreciate even more that I have not been "flamed" or "bashed". I suppose this might be one of the differences between owning a VW (vwvortex) and owning a Saab!
I went through a lake, errr puddle, deeper than that. There was muddy water on the inside of the TOP of my airbox. Luckily nothing bad happened to the car, but I changed the oil regardless. You won't get any flames from me.
The starter doesn't make any noise and the engine has not even begun to turn. When I move the key from "on" to "start" there is no difference in function under the hood. The starter was tested by the mechanic and said to be in good working order, I am not sure that the electric signal is even making it that far, is there a wiring harness that may have been damaged or unplugged?
I really think your car needs to sit and dry out for a while. Change the oil and plugs while your at it. I hate electrical problems but our cars love em.
Yea, when it comes down to the really hard electrical problems, the stealership or a really good Indy is the only real way to solve it. Just my opinion >
Sadly I don't know any good indy shops, so it looks like the answer I was avoiding might be the only answer. I wonder how my luck will be getting this covered under the extended warranty...I am still browsing the WIS for anything I haven't tried yet.
Try and do some research on that and call your dealer tomorrow and talk to the service guy. Just say your car is not running and that's it, get an appt. This will also give your car time to dry. Do you have a garage? Heated? If it covered your window issue it should cover this. Just play dumb
It is at a mechanic's now and has been since Saturday, I am not sure if it is indoors at the moment, but I would imagine under the hood should be mostly dry. I will let you know how my luck with the dealer goes. Thanks again for all the help every one has offered.
Related Threads
SaabCentral Forums
3M posts
119.2K members
Since 2001
