Very hard shift from P to R - is my tranny going crap out soon? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-5 Mk.I, 1998-2009 > Saab 9-5 Workshop
Saab 9-5 Workshop Saab 9-5 Workshop (1997 to 2010) Technical Forum
Old 26-06-12
hanbui hanbui is offline
My Saabs: 2002 9-5 Wagon and 2000 9-5
Default Very hard shift from P to R - is my tranny going crap out soon?
2002 SAAB 9-5 2.3L, I have had nothing but problems with SAAB.
What can be the causes of the above symptom?
Is the tranny going to crap out at any moment now?
Your advice is greatly appreciated
Old 26-06-12
bwasson's Avatar
bwasson bwasson is offline
My Saabs: 9-5 Turbo Wagon
If you can get under it, check out the transmission mount. You should be able to see it pretty easily with the car lifted up a little bit. There's a black bit of rubber on the inside of it, see if this is torn. I'd say this is likely the cause. I just ordered the poly insert from GenuineSaab.com for $35 ($45 with shipping).
Old 26-06-12
Norm95 Norm95 is offline
My Saabs: 9-5 JZW lll 44 mpg, 9-5 SC stg IV 39 mpg
Not sure of the mileage and assuming athe fluid has been changed, you can lean under the front of the car and see the front tranmission mount.
Old 26-06-12
fels fels is offline
My Saabs: 04 9-5
Does it always do it? Or just in a certain driveway? Assuming its automatic it could just be a slant in your driveway or wherever you park. If that's the case try engaging the e brake before you put it in park,then put in park. When you're ready to leave put it in reverse and then put e brake down.
Old 26-06-12
Paul in NM's Avatar
Paul in NM Paul in NM is offline
My Saabs: 02 Aero SW JZW III
I have it with my 02 Aero. Common issue. Can be alleviated quite a bit with a solid trany mount available from GS.
Old 26-06-12
thanks for all the replies
I understand that the front tranny mount is "easier" to replace than the rear one.
could someone point me to a link please, pix would be best
Old 26-06-12
bwasson's Avatar
Manual: http://www.genuinesaab.com/catalog/p...roducts_id=848
Automatic: http://www.genuinesaab.com/catalog/p...roducts_id=741
Crap!!! After smooth engine swap transmission wont shift into gear, wont engage erh7771 Saab 9-5 Workshop 13 21-05-12 10:12 AM
Occasional hard/hesitatant shift during hard acceleration 03saabfan Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 1 30-10-10 12:50 PM
hard shift into 3rd afstud6900 Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 2 19-04-10 08:36 AM
Paddle Shift Question: when hard acceleration it wont shift out of 1st... CODE Saab 9-5 Workshop 0 14-03-08 11:01 AM
Hard to shift knowtion Classic Saab 900 Workshop 3 14-12-07 05:45 AM
