My car has recently been losing coolant when I drive it hard. When I come to a stop I can see steam coming out from under the hood on the front passenger side, and occasionally there will be a small puddle under the car in the general area of the turbo.
I recently changed the upper and lower radiator hoses when I put the viggen intercooler on, so I know that those are fine. The radiator also looked to be in good condition.
My suspicion is that one of the turbo lines has a small hole or crack that allows it to leak under high pressure, as I dont lose coolant or lose very little if I drive the car gently. I cant locate any 'wet' areas around the turbo, as I'm sure any coolant that leaks out is immediately burnt off.
Does anyone have a diagram of the coolant lines to the turbo that I could see, and does anyone have any other suggestions as to where this leak could be coming from?
