Fuel tank repair - SaabCentral Forums
Go Back   SaabCentral Forums > Saab C900, 1979-1993 & '94 Convertible (C=classic) > C900 Workshop
C900 Workshop Classic 900 (1979-1993 & '94 Convertible) Technical Forum.
Old 3 Days Ago
milos milos is offline
My Saabs: '86 900 8V, '90 N/A 900
Default Fuel tank repair
Fuel tank on my c900 has a hole on the top side (PO installed LPG system and they menaged to put a hole in the tank). So, I want to weld/repair it with some HDPE plastic and soldering iron. Anyone tried this before? Is it a good idea?
Old 3 Days Ago
secondsaab's Avatar
secondsaab secondsaab is offline
My Saabs: '91T16Vert/'92T163dr/Frknblue/'989000CSE
i used fuel resistant glue to seal a crack in my '91 tank several years ago. 3M.
Cannot remember which, JB weld is defined as fuel resistant if filling a hole.
Old 3 Days Ago
Thanks!
May check for 3M glue, JB weld is not available where I live.
I was told to try with windshield glue...
I am leaning toward hdpe plastic as it is suposed to be the same material as fuel tank (is it?) so basically, it would be welding. If done right, there is no guessing if glue or some kind of seal would stick to plastic.
Old 3 Days Ago
peva's Avatar
peva peva is offline
My Saabs: '94 T16 Ruby 3dr, '93 T16 Ruby Vert.
http://www.innerduct.com/hdpe-glue
Old 2 Days Ago
I have found some old thread where Jim M. suggested that PO would probably need to replace some fuel line after tank removal. Not sure if that was about that specific case where rear suspension welding was involved or I should expect some broken fuel lines(?). Could anyone (Jim) clarify this?
David's DIY--Plastic repair for radiator or fuel tank etc davidlyx 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 1 28th March 2014 12:17 PM
David's DIY--Plastic repair for radiator or fuel tank etc davidlyx NG900 & OG9-3 Workshop 0 27th March 2014 10:31 PM
Fuel Tank / Gas Tank princeben C900 Workshop 1 12th November 2010 10:58 AM
Fuel Tank Repair SDS-PAGE C900 Workshop 7 20th January 2010 03:16 PM
Empty Fuel tank, final moments? Symptoms of empty fuel tank? ShadowWorks C900 Workshop 36 14th December 2005 08:15 PM
