where is the best thread (with pics) for 95 900 E-brake adjustment? - SaabCentral Forums
Old 4 Days Ago
Per's '95 NG 900 5spd Per's '95 NG 900 5spd is offline
My Saabs: 95 NG 900 5spd 190,000
Default where is the best thread (with pics) for 95 900 E-brake adjustment?
sounds like real PIA.
IIRC someone said better to remove rotors???
Do I flip the little thing up or down? Same on both sides?
I'm also not seeing exactly what I"m suppose to adjust under the car.
How about a pic with the exact part I need to turn circled?
Old 4 Days Ago
Kei's Avatar
Kei Kei is offline
My Saabs: 1995 900 SE stage 3 @ 188k
Garage
This is the best guide I've used. The fixed caliper 9-5 is the same as the 9-3 and the 900.
This is the adjuster that you need to turn through the disc. On the right side of the car, the star-shaped wheel has to be turned downward to tighten the handbrake. Upward on the left side.
Old 3 Days Ago
EdT EdT is offline
My Saabs: 1997 900S Coupé, 2003 9-5 Linear Wagon
I am extremely puzzled by that picture. On my 900 (and on my later 9-5) the adjuster is at the bottom.
The adjuster can also be installed in either direction, so which way you turn to loosen depends on how it was reinstalled. I would go with the info above, modify if it clearly isn't working. Note, unlike all the proper drum brakes I've worked on, the adjusters aren't left side/right side, so if they both have the starwheel forward, you will have to turn them in 'opposite' directions, i.e. up to loosen on one side, down to loosen on the other.
Old 3 Days Ago
Kei's Avatar
Kei Kei is offline
Garage
I'm guessing that the photo was taken from below looking up at the bottom of the hub. My 900 is also definitely star wheel at the bottom.
Old 3 Days Ago
EdT EdT is offline
Yeah, you're right about the angle, the previous picture has the caliper to the right; the starwheel picture has the caliper ears to the left. Everything else looks pretty correct. Nice think about 900/9-3, there's a lot better access to the caliper retaining bolts than there is on the 9-5.
Old 3 Days Ago
jakejm79's Avatar
jakejm79 jakejm79 is offline
Saabista
My Saabs: 1999 9-3 Convertible
The early 9-5 had the adjuster and actuator swapped, i.e. the cable connected to the actuator at the bottom of the hub not above it like on the 900, 9-3 and later 9-5.
Old 3 Days Ago
EdT EdT is offline
Oh, to add, once the shoes are adjusted properly, there should be an adjustment in the cable. If you are lucky, it's not 100% seized. There are a couple of cable designs; I don't have EPC to check what a 1995 would have, or where you'd adjust it.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
'98 900 parking brake adjustment Brian D. NG900 & OG9-3 Workshop 15 13th November 2012 04:21 PM
emergency brake adjustment help 92 900 pmcag C900 Workshop 3 2nd October 2011 07:44 AM
New rims: This thread is useful with pics PeriSoft The Lounge 15 18th July 2010 09:52 PM
Need some help with auto shifter adjustment. (PICS) axialflow1680 C900 Workshop 2 9th October 2009 09:10 PM
E-brake adjustment? fastazzgtp1 NG900 & OG9-3 Workshop 5 10th December 2004 08:22 AM
