Death Rattle? - SaabCentral Forums
Old 4 Days Ago
rauffrey rauffrey is offline
My Saabs: 2001 9-3
Default Death Rattle?
I've heard and read about a few different clicks and rattles on this forum this morning but none describe what I hear. I'll describe it and ask it it's familiar to anyone:
Usually heard at low idle, say like at a light. All will be fine until something starts to go "lagga lagga lagga". Almost like it's a pulley not always in play coming loose. That idea would point to the AC somethinorother but I'm unfamiliar with the whole setup. If I rev the engine it will stop but may return quickly.
Does this sound like a common thing? I'll pull the belt and spin things but figured I'd ask while I'm stuck in the office...
Old 4 Days Ago
lms's Avatar
lms lms is offline
Pull belt like you state, go from there. How many miles, ever see the oil pressure light? Exhaust, sometimes a loose exhaust will rattle until you get going?
Old 4 Days Ago
multisaabguy multisaabguy is offline
My Saabs: (2)'99 verts,(2)2k vert&htbk,(2)02 vert
pull the belt on a cold engine so you can run it for a few minutes, a bad alternator will sound like rocks in a dryer, but you can isolate the A/C with the short belt.
too many Saabs 99 93SE convertible,00 hatchback
99 93 convertible,00 93SE convertible
01 93SE convertible(2)02 93SE verts
Old 4 Days Ago
My Saabs: 2001 9-3
About 121k miles. No oil pressure indicator since ownership (1 month). I don't think it's exhaust. It really does sound like some pulley. Just concerned it may be water pump, not auxiliary thing like AC. There had been some rubber burning smell when using the ac not too long before this rattle started. As you can tell I suspect the ac. The noise also has a distinct oscillating sound. It really sounds like something that revolves is coming loose or a rubber bushing burnt up and the pulley it padded is flopping around. It's definitely in the front of the engine, where alternators, fans and other belt-driven things live.
The sound is just so unique that I thought if I described it someone might say "Yup. That's the frakas rod muffler bearing for sure". Maybe less lagga lagga and more woogga woogga with a wob wob wob undertone. I wonder if I could record and post it. I'm locked down so tight at work I have to use my phone just to post on here...
Old 4 Days Ago
steve12955 steve12955 is offline
My Saabs: 1999 9-3 215K; 2008 9-5 150K
If it's coming from the passenger side and you have a large (18" or so) breaker bar or 1/2" ratchet extension - WITH THE ENGINE OFF - find the serpentine belt tensioner hole which faces up. It's about 1/2" square. Insert the bar or extension and lever the tensioner forward so you know how it moves. Then, with the engine idling CAREFULLY lever it again. If the sound lessens or goes away when you take tension off the belt then you know it's one of the pulleys that's belt-driven: tensioner pulley, idler pulley, water pump, power steering pump, ac compressor, alternator. Remove the bar. Then, with the engine idling use a mechanic's stethoscope, long screwdriver, ratchet extension, breaker bar, etc. and CAREFULLY probe whatever belt-driven accessories are suspected. If you place one of these bars on the item and hold the other end near or against your ear it will be apparent where the noise is coming from. Again, be careful with the engine running with a rotating belt!
Old 4 Days Ago
jvanabra jvanabra is offline
My Saabs: LOTS. :)
FWIW, I have seen several cars make terrible noises from failed serpentine belt tensioners - you can usually eyeball them pretty easily by shining a light down on them (back the engine, in front of the firewall, passenger side) and watch them jiggle around in time with the noise.
Old 3 Days Ago
My Saabs: 2001 9-3
Thanks gents. These are good pieces of advice. I have to get the heat shield off and spend a little more time investigating. By any chance does anyone have access to WIS (still don't even know what that stands for) diagrams of this area? It's a 2001 9-3 turbo 2.10L.
Old 3 Days Ago
EdT EdT is offline
My Saabs: 1997 900S Coupé, 2003 9-5 Linear Wagon
WIS is Workshop Information System. Go to the Tech II workshop, where' there's a sticky of WIS to download that works fine on Windows 10. It's invaluable in troubleshooting, seeing how things go together, etc.
Old 3 Days Ago
My Saabs: 2001 9-3
THIS is the sound (not my vid but seems to be quite common): https://youtu.be/jRUrFHkdRAg
Old 3 Days Ago
My Saabs: LOTS. :)
Oh yeah, that's definitely an AC compressor. That's easy to diagnose... just turn it off. Happens to all cars. I had a Saturn with a dying compressor, sounded the same whenever it was on.
Old 3 Days Ago
My Saabs: 2001 9-3
I don't think so. This happens whether the AC is on or off. In order to eliminate the compressor I've read here that you must install a smaller diameter serpentine belt. Unfortunately, June/July not the best time to be eliminating the AC.
Old 8 Hours Ago
My Saabs: 2001 9-3
Saab Masochists,
So the screaming pulley got bad yesterday and pretty much completely seized today. On the way home I could smell the serp belt burning periodically. When I parked it I noticed smoke coming from the front right of the car and got the flashlight on my phone out just in time to watch the serp belt MELT on what I think is the AC compressor pulley.
My questions to you are:
Is the short belt i need to temporarily eliminate the AC an 1805mm (71") 6-rib belt such as the Autozone 6pk1805?
What is the length of the full size belt (in case I manage to fix the ac at some point?
Is this diagram correct for a 2001 2.0 Turbo manual trans base model?
http://serpentinebelthq.com/1999-saa...-belt-diagram/
Am I supposed to eliminate any other pulleys?
Does anybody know of a non Saab (cheap) idler pulley replacement part?
How do you get melted serpentine belt out of your 3rd degree finger-burns?
Thank you Thank you Thank you
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Death Rattle and Knock - Costs? Anyone ever had it done? NewBoySaab C900 Workshop 6 16th April 2005 07:14 PM
death to rattle GearHead C900 Workshop 8 7th February 2005 03:18 PM
Death Rattle update, thanks all 99Saabnut NG900 & OG9-3 Workshop 2 4th March 2004 08:26 AM
Is it a Death Rattle?!? A Little help please! 99Saabnut NG900 & OG9-3 Workshop 9 3rd March 2004 06:47 PM
The Rattle of Death fabric NG900 & OG9-3 Workshop 15 2nd March 2004 04:47 PM
