Key stopped working - SaabCentral Forums
Old 1 Week Ago
myredsaab myredsaab is offline
My Saabs: 2001 Saab 9-3
Default Key stopped working
I wonder if anybody can explain and help to solve the issue. Saab 9-3 2001, my ignition key stopped working first stopped remotely opening the doors and today stopped starting the engine. On the display I can see the message "not correct key" or something similar. I have two other keys and they both work without any problem. I checked the battery and it shows full 3V charge. I clean transmitter with electrical connectors cleaner, replaced battery with completely new one and still no effect. As I said the other keys, which luckily i have, are working. So what is the explanation? Don't ask me why I need three keys. It can lead to divorce and breaking family...
Thanks a lot
Old 6 Days Ago
Mimmi's Avatar
Mimmi Mimmi is offline
My Saabs: 9-5 Aero my-06 & my-08 1,9TiD Hirsch
Key uses battery ONLY for remote.
IMMO uses chip, chip do not need battery.
After battery replacement, you have to re-sync remote by pressing door open button several times next to car.
Unfortunately this will not re-sync IMMO and chip.
Best solution now is re-marry key with TECH2.
Old 6 Days Ago
As I wrote in my original message original battery was OK. I just replaced it to be sure that it is not battery. Remote control is not working after performing re-sync few times. It still does not explain while IMMO stopped working? Am I correct?
Old 6 Days Ago
EdT EdT is offline
My Saabs: 1997 900S Coupé, 2003 9-5 Linear Wagon
By the way, this should be in the "Workshop" forum.....
The simplest explanation is that the module that holds the buttons is damaged.
As Mimmi said, there are two functions the module does:
  1. Has security transponder (built in, nothing to do with battery)
  2. Has remote transmitter (needs battery)
I have had the transmitter fail, but the transponder was still good.
The only way you can really find out what's going on is to hook up a Tech II diagnostic instrument. It can tell you if the security computer has "forgotten" about this one key, or whether it knows about it but the key is not working properly. There's nothing really else you can do; you have tried re-synching the remote by pressing it a bunch of times. (You can try some more, maybe it will help--but for the remote only, won't help KEY NOT ACCEPTED message.)
The security module does come out of the key--when you open it up to change the battery, giving the buttons a good push pops it all out. The good news is that a working module can be installed. The bad news is that:
  1. You need a security module (they are available for "free" in some junkyards, otherwise find one on-line)
  2. The module needs to be programmed to your car using Tech II (both the security transponder and the remote).
Old 6 Days Ago
jakejm79's Avatar
jakejm79 jakejm79 is offline
Saabista
My Saabs: 1999 9-3 Convertible
You could always press the trunk button I believe while the key is in the ignition this should tell you how many transponders and remotes are programmed in the TWICE. That might give you an idea about if the transponder chip has failed or if the TWICE has somehow forgotten one.
Old 6 Days Ago
Thank you all,
Jakejm79, how exactly should I do it? Should I use not working key? And should I press the trunk button on the key or on the door?
I did replaced the key before (that is why I have 3 keys now) It cost me close to $100 just for module from ebay and programming at the Saab Service. Given that I havve to working key now I don't have to do it at least now. But obviously would like to know what happened and why.
Old 6 Days Ago
I managed to check with the TRUNK BUTTON. Display was 2 remote keys and 2 transmitters
Old 6 Days Ago
Saabohème's Avatar
Saabohème Saabohème is offline
My Saabs: 2008 9-3 SS 2.0 6Spd JZW Stage 1
When you are right, you are so right, right? Moving it there now. Right now.
Old 6 Days Ago
jakejm79's Avatar
Saabista
Sorry trunk button on the remote/key and yes a working key.
If you had 3 keys and remotes but only showing 2 on the SID then it sounds like the TWICE has somehow forgotten about 1 set. I'd verify that both the 2 other keys and remotes work properly.
You will likely need a TechII (or someone with one) to reprogram the TWICE for all 3 keys/remotes. You will need all of them present when you do that.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Both key fobs stopped working euromotor 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 2 23rd September 2015 07:46 PM
key stopped working mpnguyen1 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 24 27th March 2012 04:04 AM
Key Fobs Stopped Working Malibu 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 9 14th February 2011 03:58 PM
Key Fob stopped working? Barr 9-5 Workshop 1 13th July 2010 02:57 PM
Key Fob Stopped Working dlmetzger 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 19 30th June 2004 12:32 PM
