Hot engine - SaabCentral Forums
Old 1 Week Ago
05Aero21's Avatar
05Aero21 05Aero21 is offline
My Saabs: Steel Grey 05 Aero automatic 02 Saab 9-3
Garage
Default Hot engine
B205..... probably stating the obvious here, but temps mid to high 80's, light city traffic, stop/go stuff. Rad. fan kicks on a lot more than 05 9-5 does in same weather.
Know their not the same engines, but at times if I go out and start car again say 10 min after, I think will buck and nearly stall before smoothing out.
Let it go longer, starts are normal. Fine in any other driving situation. But yeah, runs hotter than the B235r.
Old 1 Week Ago
05Aero21's Avatar
Garage
Using 5w40 syn, coolant fine, Zeneca G-05. Correct NGK plugs...
Old 1 Week Ago
05Aero21's Avatar
Garage
Zerex.... hate autocorrect!
Old 3 Days Ago
CarpeCyprinidae CarpeCyprinidae is offline
My Saabs: 1997 Saab 900S Convertible 2.0 N/A
My B204L also triggers the fan more often than i expect a similar car to do so (have previously owned a Volvo and a VW with 136bhp 2.0 litre 4-cyl engines) but in my case it didnt seem detrimental to the running
I just made two extra electrical connections... wired from the switched (negative) coil terminal of the high speed fan relay to a pair of heated seat switches. (cut off ball point pen through the firewall grommet as a wiring guide)
One of them turns on the fan and keeps it on so I can pre-cool the coolant before reaching heavy traffic, the other links or unlinks it to the handbrake switch so I can force constant cooling while stationary. I had to use a few diodes to prevent the circuits interfering with each other and/or confusing the ECU but it was very straightforward
Mine came to me with 5w30 in the sump and I immediately switched it to 10w40 as it seems smoother with thicker oil
Old 3 Days Ago
Kei's Avatar
Kei Kei is offline
My Saabs: 1995 900 SE stage 3 @ 188k
Garage
If you have aircon, the rad fan comes on to cool the condenser which happens pretty frequently for short durations.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Hot days / hot engine fuel? trouble misu 9-5 Workshop 0 20th July 2014 04:55 AM
CEL on Cold Engine not on Hot Engine Sewingkit 9-5 Workshop 2 15th April 2014 06:55 PM
Engine Swap 2.0-HOT to 2.3 Viggen-like Engine? SaabNowSobLater NG900 & OG9-3 Workshop 18 27th November 2012 05:12 PM
Warning Message: Hot Engine! Make a Safe Stop. Idle Engine. Smudger78 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 6 11th September 2012 04:24 AM
tapping noise from engine only when engine gets hot GM900 scb NG900 & OG9-3 Workshop 8 10th November 2011 06:16 PM
