Whirring noise from transmission - SaabCentral Forums
Old 1 Week Ago
GREYCLOUD GREYCLOUD is offline
My Saabs: 1999 9-3 2lt turbo convertible
Default Whirring noise from transmission
Hi
1999 2lt turbo has whirring noise from auto tranny.
most notable at low speeds. Checked the trans fluid today. (red/brown)
Did first flush drain from transmission today. Still noisy.Will do second flush tomorrow.
Any ideas? thanks in advance
Greycloud
Old 1 Week Ago
EdT EdT is offline
My Saabs: 1997 900S Coupé, 2003 9-5 Linear Wagon
More info would help. Does it change in pitch with road speed or engine speed? Does it go away at higher speeds (when the torque converter would lock up)?
Old 1 Week Ago
Hi EdT
Hmm....not sure what you mean by 'road speed or engine speed"?
However when when I put the car in "drive" there is no whirring until the car starts to move,then the whirring rises in pitch as i increase speed. As the gearbox moves into second the whirring pitch lowers in pitch and rises as my speed increases. The whirring sound does seem to be less audible at higher speeds when the car has shifted into fourth.
When I slow to a stop - it (whirring noise) , goes from a high to low pitch as I assume the gearbox goes back into first gear.
Thanks for your help.
Old 1 Week Ago
EdT EdT is offline
Engine speed is RPM, changes due to gear shifts/neutral, whereas road speed is just how fast the car is going. So your noise goes with engine speed. So my guess is that it's the torque converter. They can make some fairly high-pitched noises that could be described as "whirring" without anything being greatly amiss.
I would expect those noises to be diminished when the converter locks up, which would definitely happen at some point in top gear, and possibly in lower gears (I'm not that familiar with this unit).
Do the second flush and make sure the fluid level is correct at the end of that. Unless the noise gets a lot louder, the transmission fault light comes on, or you start getting funny jerks or other strange behaviour, I'd say there's nothing to worry about--and nothing obvious to be done.
Old 1 Week Ago
Hi EdT
did the third flush yesterday and took the beast for a drive today. I think the noise has diminished slightly, but it still whirs.
Thank you for your replies and your soothing words.
I have owned 4 saabs, two of which had expensive transmission problems, so I have been quite nervous
I will try to relax.
Thanks
Greycloud
Old 6 Days Ago
EdT EdT is offline
I can understand being nervous!
I don't know if there are any TCM fault codes that don't turn on the gearbox light. WIS would tell you. You'd need a Tech II to check if there are any codes set by the transmission controller.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Whirring noise on our Aero soymllk 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 3 7th September 2016 10:25 AM
Whirring noise yamaha42 9-5 Workshop 10 6th September 2013 09:37 PM
Whirring noise SleeperSaab NG900 & OG9-3 Workshop 28 8th September 2011 04:22 AM
Odd whirring noise after a new auto transmission mattysavager 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 0 13th April 2010 09:22 AM
Whirring and whining noise cgale NG900 & OG9-3 Workshop 6 15th April 2002 09:29 AM
