Central warning light & oil pressure warning light - SaabCentral Forums
Old 1 Week Ago
marcdavid marcdavid is offline
New Member
My Saabs: 2001 93 SE convertible
Default Central warning light & oil pressure warning light & POP
I have a 2001 9-3 Convertible with 190k picked up a few months ago and have been working on and driving. Great fun to drive. I initially added Lucas engine stop leak to see if it would help with some leaks and the start up exhaust smoke. Then changed oil after running Seafoam through for a day or two or easy driving. Temps have been in the upper 80's and it seems to run hot and trigger the central warning light and oil pressure warning light especially in sport mode. After this weekend I have since read about the sump issues and clearly need to drop the pan and investigate.
However, my primary issue of this post is while driving this weekend on the interstate for 5 miles in high temps and perhaps running it a bit hard we heard a pop and lost some compression. We slowed, made our exit and it died. Let it cool for a bit, restarted and made it another mile. Same thing again and made it to our destination. No fluid loss. Let it sit overnight, started fine and was able to make it home, 8 miles easy driving. The central warning light & oil pressure lights were flashing, it never died but it is making a new low sounding clicking or tapping noise. Not a lifter sound.
How can i attach a sound file for you fine folks to listen?
Thank you in advance
Old 1 Week Ago
lms's Avatar
lms lms is offline
This is just a guess, but since you were getting a low oil pressure warning, now you are getting a mini knock, then the bearing(s) might be toast.
You need more posts in order to attach files.
Lucas, seafoam have their applications, but on an old turbo saab car, what usually happens is that it makes it worse as it dislodges all the gunk/sludge.
A pop in these cars usually is a Turbo hose letting loose, or something boost/vacuum related.
Old 1 Week Ago
jakejm79's Avatar
jakejm79 jakejm79 is offline
Saabista
My Saabs: 1999 9-3 Convertible
Roll it into the junkyard and buy another one, this time drop the pan (or make sure there is documentation of it having been done recently) when you buy it.
Old 1 Week Ago
jmkcc's Avatar
jmkcc jmkcc is offline
My Saabs: 96 900 vert; 97 900se vert; 00 9-3vert
Or find a parts car with good motor and swap it. You can also rebuild if you are ambitious. But a knock may indicate crank or rod damage which gets prohibitively costly.
Old 5 Days Ago
New Member
pulled valve cover and pan, heres pictures...
thoughts appreciated on next steps
ID:	216618   Click image for larger version
ID:	216626   Click image for larger version
ID:	216634   Click image for larger version
Old 5 Days Ago
lms's Avatar
lms lms is offline
Looks like its sludged up. Clean the crap out of the strainer, oil pan, etc. with oven cleaner. Did you pull the chain tensioner, the chain looks slack, if not pull it and measure. Put it back together, new oil filter, run some cheap oil, get it hot, drain it, then refill and see what you come up with. People have been lucky this way. But if it knocks on the first start up with cheap oil, well...
Old 5 Days Ago
jakejm79's Avatar
Saabista
You'll probably want to plastigauge the bearings before putting it all back together.
Old 5 Days Ago
mbriet mbriet is offline
New Member
My Saabs: C900, 9-3 convertible
You might want to check the harmonic balancer / crankshaft pulley just to rule this out:
forums/showthread.php?t=457369
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Central warning light low oil Gen-X'er 9-5 Workshop 18 18th March 2014 12:53 PM
oil pressure & warning light when braking. (not sensor.) 93Se93Se NG900 & OG9-3 Workshop 11 8th May 2012 12:07 AM
Oil light flicker & warning light after 45min 9-5pwner 9-5 Workshop 10 21st May 2009 01:05 PM
central warning light, flashing engine light, and battery light haedong12 9-5 Workshop 6 20th June 2006 02:56 AM
HELP! Oil Pressure Warning light ESSEX BOY UK NG900 & OG9-3 Workshop 1 20th April 2004 02:44 PM
