Central locks - Page 2 - SaabCentral Forums
Old 2 Weeks Ago
jakejm79's Avatar
jakejm79 jakejm79 is offline
Saabista
My Saabs: 1999 9-3 Convertible
You should be able to at least inspect it with only the door panel off.
In theory it should only effect the door where it is bad, possibly but unlikely both are bad, but also it may be in a weird position throwing off the DICE or something.
Old 1 Week Ago
Flash635 Flash635 is offline
My Saabs: 900s Convertible 1998
I can't see what's going on with the locks.
On both sides the lock actuator will make a chnk noise that can be felt on the snipper when it's supposed to be locking but there's no movement.
It's not the deadlock or the rod that actuates it, when the deadlock is engaged there's no sound at all.
I can't get the lock mechanism out to look at it though someone with sub Trump size hands might be able to. And if I did I don't now if I'd be able to reconnect the actuating rods, there's no room in there.
I can't see it being the solenoid as both sides went at the same time.
The module is ok because all the locks are getting signal.
The solenoid isn't jammed, the snipper and the key work freely.
  #23
Old 1 Week Ago
williamson.298 williamson.298 is offline
My Saabs: '99 9-3 base turbo 5speed
Stick your phone in there and snap a pic to inspect. This is the drivers (LHD) side. Black plastic part(s) are broken on this one and required replacement.
  #24
Old 1 Week Ago
Thanks for that.
How did you get the clips for the actuating rods undone? And then could you do them up again when you replaced the mechanism.
When I said I can't see what's going on with it, I meant I don't understand what's wrong. I can see it, my back is stuffed now but I saw the mechanism.
  #25
Old 1 Week Ago
For 3 of the 4 clips - left 2 and bottom right in second pic - check out this ebay pictorial.
The top right doesn't really clip; the rod pulls out when the assembly is removed, and you have to feed it in when re-installing. It was a PITA and left my hand sore and cut, but it's doable.
  #26
Old 1 Week Ago
It says the listing has been removed.
I'm looking forward to taking the skin off my knuckles.
I've got a daughter with small hands that I sometimes get to help me with stuff like this, I have to get her in the right mood. 15 year old girl.
Something I'll try tomorrow is to apply voltage directly to the solenoid, see what happens.
It's doing a little bit, just not much.
  #27
Old 1 Week Ago
  #28
Old 1 Week Ago
I see, thanks.
  #29
Old 1 Week Ago
I went out and had another go, my hands are just too big to get in there unclip the rods.
I tried applying voltage to the wiring, the black/green wire and the blue wire; nothing, not even what I was getting by clicking the fob which was a chnk noise on 'lock'.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Similar Threads
Power locks central module ... or...? JKlaveness 9000 Workshop 17 30th January 2012 01:46 PM
No central locks when it rains muhawalter C900 Workshop 4 3rd November 2011 07:51 PM
Central Locks just stopped working Itsnotme1988 C900 Workshop 2 11th July 2010 01:52 PM
Central locks Malfunctioning! Please help! 97turbo900 NG900 & OG9-3 Workshop 10 13th January 2007 08:42 AM
crazy question about central locks tony m 9-5 Workshop 4 4th August 2005 03:39 PM
