(FAQ) Ng-900/9-3 Forum Frequently Asked Questions (FAQ) *Now with DrBoost links* - SaabCentral Forums
Old 30th June 2005
CleveSaab's Avatar
CleveSaab CleveSaab is offline
Saabista
My Saabs: 2006 9-3 SC, 2013 Volvo C70
Default (FAQ) Ng-900/9-3 Forum Frequently Asked Questions (FAQ) *Now with DrBoost links*
Below are links to previous threads about the most common questions we see here in these forums at Saabcentral. Do not hesitate to 'bump' (meaning reply to one) any of these links if you have a question, or don't understand something. If you think a thread deserves a place in here, please send a PM (Private Message) to Bkrell or myself.
Thank you.
Thinking about buying a 900/9-3??
LINK 1
LINK 2
LINK 3
LINK 4
NG900 Buyer's Guide
More Buying Advice
900/9-3 Features Section (reviews, brochures)
SC Listings
What are the differences between the 900 and the 9-3?
LINK 1
LINK 2
What is a VIGGEN?
LINK 1
What are the different SID types?
LINK 1
Programming your ACC (Auto Climate Control):
LINK 1
Engine Won't Start - What To Check First
LINK 1
Is my 1999 SE a HIGH OUTPUT TURBO (HOT)?
LINK 1
"Anybody know a good mechanic in Xyz City?"
DATABASE
The "Boost troubleshooting thread"
LINK 1
Creaking front end in low temps
LINK 1
My car tells me it's "TIME FOR SERVICE"
LINK 1
Is there anything I can do to fix missing pixels in my System Info Display (SID)?
LINK 1
LINK 2
LINK 3
LINK 4
The black trim pieces between the door are bubbling/cracking/tearing. What are my options?
LINK 1
Is there a Chiltons or a Haynes for the 900/9-3?
LINK 1
LINK 2
What type of gas should I be using?
LINK 1
Can I use an MP3 player through my factory Headunit somehow?
LINK 1
LINK 2
LINK 3
Why can't I turn my headlights off? This switch does nothing!
LINK 1
LINK 2
What kind of spark plugs does my 900/9-3 use?
LINK 1
LINK 2
LINK 3
LINK 4
Alternator replacement help.
LINK 1
Fuel Pump Replacement
LINK1
LINK2
900 Water Pump Replacement
LINK1
Cabin Air Filter Replacement
LINK 1
LINK 2
CEL indicates bad 02 (Lambda) Sensor.
LINK 1
Can I add a CD changer to the Clarion Headunit?
LINK 1
LINK 2
LINK 3
Air Conditioning Problems - Info
LINK 1
Dropping the oil pan, checking the screen
LINK 1
1994-1998 900 RADIO CODE Information
LINK 1
EVAP Control System Leak (P0507 & P0455)
LINK 1
Manual Transmission Issues
*Thanks to JMarkert for building this section*
The clutch pedal on my ng900 seems to have a lot of play. Sometimes the gears grind and it is hard to find reverse.
LINK 1
LINK 2
LINK 3
My clutch pedal feels very heavy, is there a way to fix it? AND I have to manually adjust my "self-adjusting" cable very often. Is there a way around this?
LINK 1
I'm sick of the whole cable issue. I don’t even want to bother with the manually adjustable cable. Can I put a hydraulic clutch in my car?
LINK 1
I’ve fixed the clutch cable, but I’m still having trouble finding some gears. Can the linkage be adjusted?
LINK 1
I've adjusted both the cable and the linkage, but it’s still very hard to find reverse. Is my transmission shot?
LINK 1
LINK 2
The linkage on my early ng900 feels sloppy. Can I upgrade to the newer style?
LINK 1
Can I replace the transmission myself?
LINK 1
LINK 2
How do I check/change my transmission oil?
LINK 1
What is the best oil for my manual transmission?
LINK 1
LINK 2
Modification Section
The "Clear Corners" Mod
Link 1
Leather Restoration Tips
LINK 1
What is this MBC+A thing I hear so much about?
LINK 1
TURBO Upgrade Information
LINK 1
900S
LINK 1
LINK 2
Can I add a turbo to my N/A Saab?
LINK 1
900SE & 99 9-3S/SE (t-5)
LINK 1
LINK 2
2000+ 9-3S/SE (t-7)
LINK 1
LINK 2
Heating\Cooling System
9-3 and 900NG ACC Code Listings and Diagnostics
LINK 1
Fan Speed Controller
LINK 1
The Wonderful World of DrBoost
LINK TO ALL DrBoost's insights:
*if link fails then do a member search for: DrBoost
Old 25th November 2012
SaabNowSobLater SaabNowSobLater is offline
My Saabs: Saab 9-3 Vert & Viggen
Is it possible to have a which Saab engine swaps with which stickey? Add what additional parts are necessary to do the swap. Thanks.
Old 17th December 2012
SleeperSaab's Avatar
SleeperSaab SleeperSaab is offline
My Saabs: 1999 9-3 : Sleeper Project
It's not easy to find in other threads, but here's the VIN decoding information I found most useful. (Feel free to find a link and include it)
Here's a list of what each digit means in your VIN:
1 Geographical area
Y = Northern Europe
2 Country
S = Sweden
3 Car manufacturer
3 = Saab Automobile AB
4 Product line
D = 9-3
5 Model Series
A = Saab 9-3 with driver airbag
B = Saab 9-3 with driver and passenger airbag
C = Saab 9-3S with driver airbag
D = Saab 9-3S with driver and passenger airbag
E = Saab 9-3SE with driver airbag
F = Saab 9-3SE with driver and passenger airbag
G = Saab 9-3 Aero with driver airbag
H = Saab 9-3 Aero with driver and passenger airbag
N = Saab 9-3 Viggen with driver airbag
P = Saab 9-3 Viggen with driver and passenger airbag
6 Body type
3 = 3-door
5 = 5-door
7 = Cabriolet
7 Transmission
5 = Manual 5-speed
8 = Automatic 4-speed
8 Engine variant
J = 2.0 i, B204I
B = 2.3 i, B234I
N = 2.0 T, B204L
D = 2.2 TiD, D223L
T = 2.0 T, B204E
P = 2.0 T, B204R
G = 2.3 T, B235R
H = 2.0 T, B205L
K = 2.0 T, B205R
C = 2.0 T, B205E
9 Check character
0 - 9 or X
10 Model year
W = 1998
X = 1999
Y = 2000
1 = 2001
2 = 2002
11 Place of manufacture
2 = Trollhättan
7 = Nystad
9 = Trollhättan, pilot series
12 Serial number
000001-999999
Old 17th April 2013
Eddie RUKidding Eddie RUKidding is offline
New Member
My Saabs: 900s
Default Information on Automatic Trans in 900 GM
The site seems to have lots of info on manual trans but not much on the Auto Trans. Can any one help out here?
Old 1st February 2014
welder welder is offline
My Saabs: Red 95 900 SE convertable
The link for the water pump replacement doesn't work.
Old 20th August 2014
jdavis jdavis is offline
New Member
My Saabs: 1988 900c
Hmm, still not working. Anyone know where the link supposed to point?
Thanks,
~ Jon
Old 14th September 2015
Mike9-3nm Mike9-3nm is offline
My Saabs: 2001 Saab 9-3 SE
Great help! Thanks for the post.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
