How to test the anti frost switch? - SaabCentral Forums
Go Back   SaabCentral Forums > Classic Saab 900, 1979-1993 & 94 Convertible > Classic Saab 900 Workshop
Classic Saab 900 Workshop Classic Saab 900 (1979-1994) Technical Forum.
Old 30-06-12
Grusvag Grusvag is offline
My Saabs: 1989 SPG
Default How to test the anti frost switch?
Anyone know how to test the anti-frost switch for the AC system? Also, how bad would it be to bypass it by connecting the two wires together?
Thanks.
John
Old 30-06-12
Geoff Weeks Geoff Weeks is offline
My Saabs: 900S
You test with a thermometer, it should open before 32/0 deg and close before 40 deg.
It is there to prevent condinsation from freezeing on the eveaporator and preventing air flow, Why would you want to bypass it? to test, turn on the a/c and check for power on both sides of the switch. Once the evaporator cools to the set point it should open (power to only one side) and shut off the compressor until the evaporator warms enough to melt off any frost.
If the compressor is running and you don't have reduced air flow out the vents or visiable frost on the eveaporator core (look thru the air intake) it is likey ok. It must be closed for the compressor to turn on.
Old 30-06-12
My Saabs: 1989 SPG
Where do you measure the temperature, at the vents in the cabin?
My AC cuts out sporadically and I thought if I just bypassed the anti-frost switch I could see if that was the problem.
Old 30-06-12
Jim Mesthene Jim Mesthene is offline
If you bypass the switch, the A/C will stop working, whether that's your problem or not. With the switch bypassed, the evaporator turns into a brick of ice in short order. Don't forget the low pressure switch, high-temperature switch, wide-open-throttle switch, and manual switch.
With just a voltmeter you could test it electrically and avoid all that wire crossing. There's a wiring diagram in the Stickies; Shop Manual section 3.2.
It's easier than guessing, especially if it's an intermittent problem.
Harbor Freight sells an adequate volt/ohm meter for about $4.00.
Corporations are people! If you prick them, do they not bleed? If you tickle them, do they not laugh? If you poison them, do they not die?
Old 01-07-12
My Saabs: 1989 SPG
Thank you.
Where do you measure the temperature?
Old 01-07-12
My Saabs: 900S
In the evap core itself, right next to the switch probe.
Old 01-07-12
My Saabs: 1989 SPG
Thanks.
Anyone know what the full troubleshooting procedure would be for an intermittent ac problem? Works fine for a while, then blows room temp air for a period then starts working again.
Old 01-07-12
Step 1 is to look at the evaporator when it stops working. If it's a solid block of ice, the anti-frost switch is NFG.
If it's not a block of ice, you have to test each item in the circuit. I haven't seen a c900 in years, but my best recollection is that the power from the switch goes to the anti-frost switch to the low pressure switch to the high-temperature switch to the relay. The ground for the relay goes through the wide-open-throttle switch.
I doubt that that's either very accurate or very wrong, but you could look up the wiring diagram and get it right.
Old 02-07-12
My Saabs: 1989 SPG
Thanks everyone. Will slog through it and see if I can find the culprit.
Anti Frost Switch, 92 Vert Turbo cromero Classic Saab 900 Workshop 7 27-08-11 12:57 PM
A/C Anti-frost switch removal SwimDude0614 Classic Saab 900 Workshop 1 31-07-10 10:51 PM
frost switch/ capillary tube service dasander Classic Saab 900 Workshop 9 17-05-08 12:22 PM
Autoweek's 2006 Saab 9-3 Aero Test - The Anti-Crossover timmehhhhhh Saabs News 2 21-03-07 02:49 PM
'90 900 anti-frost switch?/ AC pffester Classic Saab 900 Workshop 2 11-07-06 09:21 PM
