AC is working at 75% - SaabCentral Forums
Go Back   SaabCentral Forums > Saab NG900, 1994-1998 9-3, 1999-2002 & 03 Convertible > Saab 9-3 & NG900 Workshop
Saab 9-3 & NG900 Workshop Saab 9-3 & NG900 (1994 to 2002) Technical Forum
Old 05-07-12
andrewhong's Avatar
andrewhong andrewhong is offline
My Saabs: 2002 9-3 SE 5spd, 2009 9-3 Aero XWD 6spd
Default AC is working at 75%
2002 9-3 SE with ACC
The AC compressor was changed less than a year ago, but now that I'm hitting over 100 degree temperatures daily now, my suspicions about my car's AC are confirmed. When recycling the air and the fan is set to half, I feel cool air coming out, but it is definitely not cold. Other cars have much cooler air coming out of the vents. When I jack up the fan to full, the air actually gets warmer, where it barely feels cool. Other cars' AC are able to keep up at full fan, and in hot temperatures.
My AC does work okay in cooler temperatures (i.e. night time). But during a day that hits the 90s, I'm still sweating with my AC running. My previous 2001 9-3 had cooler AC if I recall.
Low refridgerant? Bad seal? Or am I just crazy and expect too much out of an old car?
Old 05-07-12
sdibbers sdibbers is offline
My Saabs: 1997 900s 2.3l
Are you moving at a decent speed? If this happens when parked it could be the fan on the condeser has failed. I noticed mine wasn't great in traffic but as soon as I was moving it would feel great again.
Old 05-07-12
andrewhong's Avatar
It certainly doesn't feel good when still, but even when the car is moving, it is not great. In fact, most of the times I've noticed a rise in the vent temperature is when I'm moving. Sometimes I feel a gust of warmer air, then maybe a few minutes later it will return to a cool temperature (but again, not cold)
Old 05-07-12
Have you checked for leaks? Checked refrigerant level/pressure at all?
Old 05-07-12
andrewhong's Avatar
I was going to check the refridgerant level, but I don't know where the valve is. Am I correct in assuming I can use those canisters from Wal-mart or whatever to measure and refill?
Old 05-07-12
IIRC its the valve on the slam panel, maybe get someone else's view on this to be sure. Also you can only get the can to work with the correct valve to avoid blowing up the AC system. I've used the cans with gauges on my system before but I'm a little dubious of their accuracy.
Cheers,
Steven
Old 05-07-12
earthworm's Avatar
earthworm earthworm is offline
Saab Sage!
My Saabs: '96 900S, Automatic with 148K miles, blu
Break out your owners manual - page ? well, its value is limited...same with the Haynes...
The "lo-side" service port is next to the battery , the high side is behind the easy to remove grill.
Yes! Do use the unit from Wally-World, in a great many cases it works fine.
Most AC systems will slowly lose their freon charge - much akin to seepages of oil and coolant.
Your reading, or goal should be about 40 PSI with the engine and AC in operation.
The earthworm
'96 900S, Automatic
Those who think in the past will have no future.
173K miles in the good ole USA
Headlight wipers not working / Windscreen wipers partially not working kent93 Saab 9-3 & NG900 Workshop 16 04-11-11 07:54 PM
Gas guage not working, miles til empty not working!!! wiggy69 Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 9 20-05-10 03:31 PM
Is my ESP/TCS working ? 9-3Wotcha Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 8 25-10-04 04:04 PM
instrument cluster working/not working... CaptBrandini Saab 9-3 & NG900 Workshop 2 27-06-04 07:07 PM
Cruise control working, not working, working... johkar Saab 9000 Workshop 10 19-12-03 05:30 AM
