Drilled and or Slotted Rotors? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-3 SportSedan/Convertible ('04+)/Combi, 2003-2011 > Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning
Saab 9-3 SS, Combi & Convertible Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9-3 Sports Saloon/Sedan, Combi & Convertible
Old 06-07-12
Big Kev Big Kev is offline
My Saabs: 07 9-3 2.0T
Default Drilled and or Slotted Rotors?
Are they worth the money? I live in Colorado and do drive some in the mountains. I am also a pretty spirited driver and probably go a little faster than I should most of the time. Do the slotted rotors have any impact on the life of the pads or rotors?
Are they worth the extra money?
Old 06-07-12
Laserredsaab Laserredsaab is offline
My Saabs: 2003 Saab 9-3 Linear
If 100 people answer you'll get 100 answers. I have cross drilled on my Mercedes. Helps to cool the disc down quicker. I've heard that the slotted rotors tend to wear out pads quicker, but I don't know that for sure. My sons Saab has regular. When we have to replace we'll probably go with cross drilled.
Old 06-07-12
derekwilkinson derekwilkinson is online now
My Saabs: 2006 Saab 9-3 2.0T JZW Stg 3
on our cars, the biggest improvement would be better brake pads. ebc redstuff are good.
BSR Intake, JZW Stage 3 Tune, Magnaflow Muffler, Tinted Windows, GS Strut Brace/Bushings/Downpipe, Koni Yellow Struts, Vogtland Lowering Springs, 25mm H&R Rear Spacers, Custom Leather Dash, Galaxy Tab 7, Hardwired V1, Boston Acoustics SE35, Sony Xplod 6x9s, Infinity Reference 6.5", Dual Kicker Comp 12"/Planet Audio 2500W Amp = Awesome
Old 06-07-12
awjones's Avatar
awjones awjones is offline
My Saabs: '07 9-3ss ARC
i wouldnt waste the money on slotted or drilled, unless you did a "big brake kit".
Old 07-07-12
Thanks for the replies. I went with just the standard rotor, but I did get a better pad. I am just doing the rear for now, the fronts are still good. When they go bad I will probably do the ebc redstuff pads.
Old 09-07-12
loko loko is offline
My Saabs: 9-3 2.8T aero now with a custom map
theres hardly any benefit in everyday driving, i have them purely for the looks, over here you can get them for about the same as regular discs anyway
Old 11-07-12
Hutch06Aero Hutch06Aero is offline
My Saabs: 06 Aero JZW Stage 5
www.brakeperformance.com has supercheap rotors. I bought the drilled and slotted for the extra rice factor. I didn't notice any differences. Braking is now louder ,and the brakes looks better.
Old 11-07-12
Being in Colorado my only thought was mountain driving. Keeping the brakes a little cooler in theory should make them last longer. Some of the hills out here a pretty long and downshifting in my car does me little to no good, so some times the brakes can get a little warm. In either of my Jeeps downshifting will keep me at a speed with little acceleration, but the Saab just wants to go, I blame the turbo.
When the fronts go bad I will probably try some drilled ones just to see if I can notice a difference. Prices I have found are close enough to the regular rotors that I am not afraid to throw a little extra money at the car just to see if they are better or not. I will spend extra on the pads though.
Old 11-07-12
the drilled/slotted discs are only of benefit when the brakes get hot {ie they cool down quicker} so in your situation they would be ideal for you
Old 11-07-12
pacotaco's Avatar
pacotaco pacotaco is offline
My Saabs: 04 93 arc espresso black
They make no difference, its the pad compound that is so heat dependent. If you get them hot enough to brake fade the pads you need new pads. If you get performance high heat range pads hot enough to brake fade you might need slotted or drilled, but if your getting them that hot chances are you will crack your rotors which is why blanks are better for day to day. Also blanks provide more surface area for better stopping power, and blanks are quieter and the do not eat pads as bad.
i <3 backroads.
i rule your internet.
Drilled and Slotted Rotors Cartmn192 Saab 9-5 Performance, Mods & Tuning 23 12-02-12 03:37 PM
Drilled/Slotted Rotors 06AeroTurbo Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 11 28-10-09 05:09 PM
EBC slotted/drilled rotors? MarkJ Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 11 20-04-06 08:05 AM
Slotted vs. Cross Drilled Rotors... Lotsayellowsnow Saab 9000 Performance, Mods & Tuning 5 04-12-05 04:33 PM
Finding X-Drilled or slotted rotors JFK-USAF Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 18 23-09-03 10:20 PM
