Maybe buying a pipe bender - SaabCentral Forums
Go Back   SaabCentral Forums > Saab C900, 1979-1993 & '94 Convertible (C=classic) > C900 Performance, Mods & Tuning
C900 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Classic 900 (C900)
Old 31st August 2005
Si's Avatar
Si Si is offline
My Saabs: Sensonic NG900T, a gagle of rusty c900's
Default Maybe buying a pipe bender
This is not an advertisement just a general enquiry to see if it would be worth me buying one, basically i've seen a pipe bender for around 200 that can cope with upto 3" piping, how much interest would there be in people being able to obtain upto 3" aluminium & steel prebent tubing from a friendly SC based source?
(Mods if i get a good responce i'll then look at advertising properly, this is just to see how long it would take me to cover the cost/if there's enough interest to warrant buying one........ ).
Tadek's Avatar
Tadek Tadek is offline
If you mean one of those hydraulic units like on ebay, I got one much cheaper. I am not sure how well it really will work with 3" diameter tubing. The problem ist that the tubing is too thin and diameter too big so that the tube gets squashed. Maybe it will work when you fill it with sand or something but I have not tried this yet.
alexis alexis is offline
My Saabs: 1991 900 LPT Aero
Thumbs up
My mate just bought one on ebay for around 100. Mind you, that included a rather hefty shipping fee from some place up round you. It seems a sturdy unit and can take a thick walled 3 inch pipe. The chap sells a load of them so if you buy one and pick it up I'm sure you could get one cheap. Search for 16 ton pipe bender or similar.
alan forsyth alan forsyth is offline
a set of custom ally cooler pipes for me please
Old 1st September 2005
Si's Avatar
Si Si is offline
Default Pipe bender
It's this one, 16 tonne
http://www.northerntooluk.com/produc...ult.asp?id=493
On ebay (Northern tool one looks a little nicer)
http://cgi.ebay.co.uk/BRAND-NEW-16-T...QQcmdZViewItem
Alan, i've got a price for alumin aswell, 30 for 5 meter 3" diameter, that can't be bad.
I'd start off just doing prebent sections, then once my weldings better, custom downpipes & cooler pipes, then when my welding is sh** hot i'd look at equal length headers for T8/T16 an maybe a custom header for fitting TD04's on, but that would be a bit further down the line.
Tadek's Avatar
Yes, it is this kind of machine.
Believe me, it's not that easy that you just throw in a piece of straight tubing, pump your machine and pop out a 90 bend. If you take large diameter thin wall tubing and try to bend it without filling it with sand or similar, all you will get is a squashed tube!
Si's Avatar
Si Si is offline
Default pipe bender
I kind of assumed that you'd strap the pipe in and bend it 10-15 deg, then shift it along a bit and do another bend and so on rather than just whacking a pipe in and bending it ...hey presto kinda thing.
The cheap ebay one is tempting, given the cost of straight sections of steel it would pay for it'self after making 1 exhaust.
Si's Avatar
Si Si is offline
Default Maybe definitely
Maybe has turned to definitely as i ordered it this morning .
Just waiting for some more quotes on alumin/steel tubing now.
Basre Basre is offline
Banned
Dunno Mate.. I'v built more than a Few Header systems in my time.. It's V tough to use a single tube in a Primary .. darned near impossible actually :-)
Usual method is to purchase a box of Mandrel bent tubes and cut 'n fit them as required. . reasonably priced too :-)
It does take some skill/practice to make perfect/invisible TIG welds but well worth learning.
A DIY purchasable Pipe bender, IMHO will basically allow you waste significant quantities of Tubing.
Si's Avatar
Si Si is offline
Default header
I won't try and make each pipe from a single section, just make the bends then cut and weld, only got a mig at the mo, but i'm getting pretty solid welds using stst wire & argon. It's at the end of a long line of other stuff anyway.
I'm going to make up caps for the pipes which can be clamped on, i'll clamp one on then fill with sand, clapm the cap onto the other end then bend, that way the sand wont be able to pour out either end and should support the inside of the pipe and stop it distorting to much.
That way all i'll need is 2 caps for each size of pipe.
ShadowWorks's Avatar
ShadowWorks ShadowWorks is offline
Banned
My Saabs: The Black Night, 900T
Si your doing really good, i hope the pipe bender works for you, even if you cant get the exhaust right and who can say you cant do it, you could make IC pipes easy.
There is a formula to figure out how much you can bend a pipe before it gets squashed, you have to input the pipe thickness and material thickness and its pretty accurate, any good luck.
john-w's Avatar
john-w john-w is offline
My Saabs: 1989 T8 Special
Si, just spoke to the guy next door who has a sheet metal business, he said sand would work, but to use tapered hardwood bungs in the end of the pipes rather than caps. But he said even then, you can push the bungs out. Also suggested heating the pipe as you bend it with a blow torch, but not too hot or the pipe will kink. Best sand to use would be kiln dried sand, as this will compact well.
Matthew's Avatar
Matthew Matthew is offline
Saab Mad
My Saabs: 900 S Aero Turbo, 9-5 Aero
Aren't you supposed to use a mandrel with those things?
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 2nd September 2005
Si's Avatar
Si Si is offline
Default pipe bender
If if does'nt do what it's supposed to it will be sent back. I don't mind spending a bit of time and doing it slowly so will see what the results are like, alumin is softer aswell so i may end up getting better results putting inlet piping together....will post pics of the results later next week as i've got a few spare straight sections which i can experiment with.
If it works OK and i go ahead with a full 3" zorst it will pay for itself so IF it works i think it's prob worth it.
I've got a little blow torch aswell so i'll try heating the side thats going to be stretched the most.
Alex99t's Avatar
Alex99t Alex99t is offline
My Saabs: Red 99 Turbo 2-Door
Here is one that I made earlier. It is for my 99T so the mounting flange will be different at the wastegate end to the 900T. I thought that I would get away with one straight through silencer as the turbo damps quite alot of noise. Wrong. It sounds horrid so I will have to splice in another silencer at least.
ID:	2870   Click image for larger version
Tadek's Avatar
Nice, but this looks more like a "NO silencer at all" setup!
This is still welded from sections, though.
Alex99t's Avatar
There is a silencer there, honest, it's just a bit...erm skinny. The system is welded from sections which probably is not quite as good as one piece pipes but the bends are at least nice mandrel bent ones.
pda's Avatar
pda pda is offline
My Saabs: T8, FMIC,173bhp & 228ft lb
my 3" exhaust system is made up from pre made stainless steel sections 90/45 deg elbows etc & the straight sections were cut from 4 metre lenghts
the elbows were cut'n'welded to suit the curves needed to fit the car, this gives a stronger exhaust system & looks nice too
HTH Paul
______________________________________________
Sleeper baby, no show & all GO................................
Paul
Tomarse's Avatar
Tomarse Tomarse is offline
My Saabs: LPG '80 99GL, '80 99T 2dr, LPG '93 ng900
Ooh Alex99T - Got any more pictures of that 99T exhaust?
I like the way that you have avoided using that horrible original silencer at the back by using the 2 45degree angles and the straight. Is there plenty of space under the floor of the car to do this?
And how did it sound 'horrid'. Was it just too loud?, or something else?
Old 4th September 2005
Alex99t's Avatar
[QUOTE=Tomarse]Ooh Alex99T - Got any more pictures of that 99T exhaust?
Yup. I was quite pleased with that bit at the back with the 2, 45 deg bends, it took me ages to line it up. The annoying thing is, I think that bit will have to be modded to get the second silencer in. Trouble is there is not a lot of room left in that area. If you look through Nutcases 99T thread you will see that he has a silencer in that area so it can be done. I have built this fron 2.5 inch sections (from jetex and milner off road) so space is a bit tight but not as bad as I thought, glad I did not go for 3 inch as originally intended. The over axle bend (from jetex) had to be cut in the middle and the forward section rotated to the off side to clear suspension gubbins. As for the noise, tickover is bearable but revving makes it sound like a large dog vomiting through a loudhaler (probably) so remedial action is called for. I will sort some more pictures out when it is finished and sounding better.
ID:	2889   Click image for larger version
ID:	2890   Click image for larger version
ID:	2891   Click image for larger version
