convertible top repairs - almost there - SaabCentral Forums
Go Back   SaabCentral Forums > Saab NG900, 1994-1998 9-3, 1999-2002 & 03 Convertible > Saab 9-3 & NG900 Workshop
Saab 9-3 & NG900 Workshop Saab 9-3 & NG900 (1994 to 2002) Technical Forum
Old 11-08-12
jcm jcm is offline
My Saabs: 04 93,01/95,
Default convertible top repairs - almost there
2002 with 112k.
Open issue: top needs a helpful pushback upon reaching about 2' of height. Appreciate any helpful thoughts.
With the help of a Tech 2 Saab dealer and 2 sessions at $55 each, we found a the following:
1. T-cover micro switch out. This was the probable cause of the broken u-joint in the t-cover mechanism. Donor car parts. I found it easier to just replace the whole trunk assembly purchased for $45 from a yard.
2. 5th bow micro switch. Metal lever badly bent. Replaced with donar parts. $20
3. 5th bow cylinder on the driver's side outboard - this has position switches inside it that report position of the bow. Tech 2 read showed the cylinder was reporting one position sensor showing bow open while the sensor at the other end of the cylinder was showing the bow was closed. Replaced with donar part. $25
Got it all together but the but system was still not working properly with inconsistent latching and stop chimes. So I picked up a can of Tri-flow (teflon based lubricant) and sprayed all joints. I found the cables which pulled the t-cover down stiff to the point where I could pull them up with a finger and they'd hang in position so I sprayed inside the cable.
So now the top cycles correctly except as reported above still needing a gentle push on the down cycle only. Closing cycle works perfectly.
Working on the top was only possible with the help from forum on how to unlatch the 5th bow by accesssing the left side trunk connector's gray/brown wires to lock/unlock. I employed the use of a hand drill power pack with alligator clips.
Old 11-08-12
jcm jcm is offline
fixed - found the 5th bow switch was not plugged in
SID repairs help please saab9-3 Saab 9-3 & NG900 Workshop 5 28-07-08 03:18 PM
A few repairs. Turboken Saab 9-3 & NG900 Workshop 5 30-09-07 06:09 AM
Sid Repairs MrLucky Saab 9-3 & NG900 Workshop 6 31-08-06 09:46 AM
How Much for repairs? :( 91900 Classic Saab 900 Workshop 1 21-02-02 06:31 AM
rip off repairs Peter Beard Classic Saab 900 Workshop 6 24-01-02 10:34 AM
