O2 sensor? - SaabCentral Forums
Go Back   SaabCentral Forums > Classic Saab 900, 1979-1993 & 94 Convertible > Classic Saab 900 Workshop
Classic Saab 900 Workshop Classic Saab 900 (1979-1994) Technical Forum.
Old 03-08-12
Saabturbo92 Saabturbo92 is offline
My Saabs: 1992 Saab Turbo 3 door 1999 Saab 9-5
Default O2 sensor?
I have hunted around the site for a similar problem....but havent really found what I am experiencing...i have an idle that rises and falls and eventually evens out, more noticable on hotter days...and running the ac also makes this issue more pronounced, coming to a stop light it drops below 900 then up to 1200 back to 700 up agian to 1000 back to 800 and then it comes back and settles at 900...the other part is it does not do this all the time, the only thing I found on the site is that a tired o2 sensor can cause a variable idle, I thought it may be the ICU...any ideas?
Old 04-08-12
S900t8v's Avatar
S900t8v S900t8v is online now
My Saabs: Trionic 5.5 1984 900t 8v
Don't think the O2 sensor can cause that big of a swing in the idle rpm,
I'd be looking towards an intermittent vacuum leak which the AIC is trying to compensate for, or a faulty/sticking AIC
A friend had the exact same symptoms a couple of weeks ago, turned out to be perished AIC hoses causing leaks.
Old 04-08-12
The bigger swings are when the air is on i have taken the aic off and cleaned the flap is not sticking and have cleaned the connector as well, i was thinking the same thing, intermittent vacuum leaks i did not think were possible? Well there are a couple aic's at the junk yard....
Old 04-08-12
Jim Mesthene Jim Mesthene is offline
Intermittent vacuum leaks are not only possible, but are designed into the charcoal canister purge system. I think your '92 has a solenoid controlled by the ECU for a purge valve.
I don't recommend swapping parts as a diagnostic technique.
How are you testing for vacuum leaks? How are you testing the O2 sensor?
Corporations are people! If you prick them, do they not bleed? If you tickle them, do they not laugh? If you poison them, do they not die?
Old 06-08-12
To be honest I have not, if I have to test for a leak I borrow the tool from my mechanic, As far as the o2 sensor and aic, I need to pull out the volt meter which I am no good at...but my dad is...what is the best way to test those parts?
Old 07-08-12
Put a voltmeter on the O2 output wire. It should fluctuate around 0.5 volt.
Spray carb cleaner at suspected vacuum leaks, not forgetting the charcoal canister and manifold gasket. If the voltage jumps, you've found a vacuum leak.
Old 08-08-12
Well in testin o2 sensor no where near .5 volts it is more like .08 to .23 in range so i guess that will have to go...
Old 08-08-12
The O2 Sensor "measures" the mixture. If the mixture is off for any reason, it will show up in the sensor. The trick then is to find out if the sensor is wrong or the mixture is wrong.
If you induce a rich mixture by pinching off the Fuel Pressure Regulator return line, then lean it by pulling the Fuel Pump fuse momentarily, and you see the sensor react appropriately, it's not the sensor.
Have you checked codes?
If you do this stuff exclusively for years, and are familiar with the process without referring to a manual, this diagnosis can be done in minutes instead of hours or days. The unhappy result is the customer says "That stealership only worked on it for 15 minutes and they charged me a whole hour!"
Such are the rewards of professional car repair.
Old 08-08-12
peva peva is offline
My Saabs: '94 T16 Ruby 3dr, '93 T16 Ruby Vert.
Stop moaning Jim. Saints don't moan.
Old 08-08-12
After checking the manual it is running lean, i did the carburator cleaner test with no change, i will try to get a change per your last post, the aic resistance is fine 8.2 ohms.
Old 08-08-12
Oh jim by the way i wish i lived next door to you!
Old 08-08-12
RETIREMENT
reˇtireˇment noun \ri-ˈtī(-ə)r-mənt\
a : the state of being retired
b : withdrawal from one's position or occupation or from active working life
c : the age at which one normally retires (OK, so I'm a little young)
Old 08-08-12
I think i found the problem hose was splitting on pcv valve cut reset when i switch ac on and off rpms adjust once cant seem to get a change in the readings by pinching fuel reg hose off...could be as simple as the leak from pcv?
Old 08-08-12
Jim and all thanks for the help in diagnosing without changing parts i did crack the bentley during this process so i have more diagnosis info if i need it...hate when i dont see the simple things first...but in the end its ok especially since i did not guess and buy parts just a little embarrasing...
Old 08-08-12
Originally Posted by peva View Post
Stop moaning Jim.
For some of us, it was quite lucrative, but I called it a great business to get out of. It doesn't even pay well anymore.
You don't see many old mechanics, unless they own the Shop and the kids do the heavy lifting.
Old 08-08-12
gustavm gustavm is online now
My Saabs: 1985 900spg Hillclimb car
I couldnt imagine actually being a mechanic. I love working on my car but how about working on hyundais all day.I dont blame them for charging good money .Ill bet a whole lot of them dont have the clear headed diagnostic ability our man Jim has though!
Old 08-08-12
2.0ster 2.0ster is offline
Banned
My Saabs: Classic 900
I changed a water pump on a 2005 Ford Taurus for my sister in law a couple weeks ago. A little figity but not bad at all. The modern cars are probably a bit easier to work on than our old geezers...
Old 08-08-12
SteveZodiac's Avatar
SteveZodiac SteveZodiac is offline
My Saabs: 1992 900T16s
Once you've cleared all the plastic and snazzy covers which hides the fact that an engine is an engine
Old 16-08-12
well had to revisit this since I repaired the vacuum lines and replaced the check valve still having an issue with idle after replacing lines and valve swings are smaller anyway.. reading on the O2 sensor varies from -.3 to .6...
Old 18-08-12
So after reading several times a wack to the aic fixes the problem, i tried it and it did change how my idle responds when turning ac on and off, is this really fixing the issue? I guess time will tell....but should I just replace or wack every now and then? It doesnt seem like a fix but it worked?
Sensor identification help needed: Sensor w/1 yellow wire back of block/oil pressure? nnamssorxela Saab 9-3 & NG900 Workshop 5 18-02-12 08:36 PM
Bank1 Sensor 1 Oxygen sensor heater circuit Craig03saab Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 4 06-08-09 01:11 PM
CEL Code P0133. How do i replace O2 sensor bank one sensor one? 97turbo900 Saab 9-3 & NG900 Workshop 13 08-01-07 11:23 PM
Where is Intake Air Temperature sensor and Coolant Temp Sensor? alfalfa Saab 9-3 & NG900 Performance, Mods & Tuning 8 22-03-06 11:26 PM
O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) Slaab4life Saab 9-3 & NG900 Workshop 3 21-02-05 07:45 AM
