Questions You think are too stupid to ask (9-3SS) - Page 155 - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-3 SportSedan/Convertible ('04+)/Combi, 2003-2011 > Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop
Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop Saab 9-3 Sport Saloon/Sedan, Combi & Convertible (MY: 2003 - Present) Technical Forum
Old 20-07-12
aerojon's Avatar
aerojon aerojon is offline
My Saabs: 04 9-3SS Hirsched Aero(Black)The Lady
if you want to upgrade the h7 bulbs,osram nightbreakers..
Originally Posted by EwOkiE
Any chance you could give me pictures if you have any and a how to please for the aux port so I can listen to mp3s as audio CD dont hold much
http://etadyne.com/DIYaux.htm
http://www.partsforsaabs.com/product...oducts_id=2716
http://saabdocs.com/English/instructions/32000102GB.pdf
I'd rather push my SAAB than drive a FORD or anything FRENCH..
ICM3 13sp system now with bluetooth audio streaming..
Old 20-07-12
EwOkiE EwOkiE is offline
My Saabs: 9-3 1.8T 2004
Thanks for that
Will this depend on what stereo is fitted in the saab or it universal
As pressing the SRC button on the Steering wheel doesnt say AUX on the SID ??
Saab 9-3 1.8T
[54] 2004 > Petrol
Old 20-07-12
aerojon's Avatar
if aux doesn't show up when scrolling thru,it's not enabled,dealer or saab indy with access to tech2..
doesn't matter which icm you have..
aux in cable fits into the ehu which is located behind the CC panel,what you see in the dash is just the control panel..
Old 21-07-12
Also checking on the H7 Nightbreakers Plus you mentioned
Noticed that they have choices Low and High Beam ... take it its Low I am looking for as both bulbs are the same and its normal headlight bulbs I am looking for
As thats 2 sets I have used (5000K/6000K) and they arent that bright and also noticed that they seem to bend to the left after a day and the SID displays dipped light failure
These ok ?
BULBS HERE
Saab 9-3 1.8T
[54] 2004 > Petrol
Old 21-07-12
What is it with my car ..its sits low!.. scraping things
Can someone tell me there distance from middle of wheel arch to ground (front and rear) incase my springs are shot!
Saab 9-3 1.8T
[54] 2004 > Petrol
Old 31-07-12
Naks's Avatar
Naks Naks is offline
Location: Gordon's Bay, Republic of the Western Cape, South Africa
My Saabs: 2008 9-3 Aero Convertible 2.8 V6 TS AT
Anyone else think that the DTW function displaying 'Refill fuel now' with 30km to go is stupid?
I mean, when you are running out of fuel, you actually want to know how much further you can go, not so?
Old 31-07-12
hotsizzlesauce hotsizzlesauce is offline
My Saabs: 2004 9-3
My windshield wipers have the option of 0, AUTO, 1, 2.
It seems like:
1 is constant slow
2 is constant fast
AUTO will change depending on the amount of rain (which is okay... since I seem to have Rain-X right now... but afraid it may not be sufficient without Rain-X)
Is there anything in between, such as wipers on delay? Every 3 secs? 6 secs?
Just bought a 2004 Saab 9-3 used... very excited and loving it. So many gadgets inside though that I don't understand. This is one of em. Haha
Old 02-08-12
Pizzaboy12401 Pizzaboy12401 is offline
My Saabs: 05' 93 ARC
Default Misfire
Never had a problem with any misfires on my 2005 93 ARC. I put a JZW Stage 2 onto it after getting my catback exhaust installed and i started misfiring around 3500 RPMs. He told me its either a Coil or Spark Plugs. I took it to my mechanic and he replaced and gaped my plugs to the right size and said that my coils are fine. We took it for a quick drive and had the same 3500 RPM misfiring. We then put the original ecu back on and then wouldn't misfire till 5500 RMPs. Any ideas on what could be going on?
Old 05-08-12
SadCar SadCar is offline
My Saabs: 2003 9-3 Vector
So I've got a bit of door damage, and the car thinks that the door is ajar, as it won't shut all the way. Is there any way to convince the car that the door is closed, until I get it in to the shop to be fixed?
Old 06-08-12
iksnoved25's Avatar
iksnoved25 iksnoved25 is online now
My Saabs: 2003 Saab 9ł 2.0T Arc
Originally Posted by Ambisaab View Post
I have had this a couple of times too !! The last time this morning in fact. I thought it was down to seat pressure so I slap the base of the passenger seat twice... and the warning goes out !!! Works for me !
I just started doing this myself, works like a charm on the 3rd or 4th try.
Old 06-08-12
IAmTodd's Avatar
IAmTodd IAmTodd is offline
My Saabs: 2006 9-3 Aero VTuner Stage 0
It does the same on the V6s. It's the coil pack going bad. A tuned engine demands more of the coils than the base tune. Find which one is misfiring and replace.
2006 Saab 9-3 Aero | VTuner Stage 0 | 280whp 324wtq | Open Intake | GS Subframe Brace
1994 Ford Explorer | 4.0 V6 5MT | Time to get muddy!
Old 07-08-12
pacotaco's Avatar
pacotaco pacotaco is offline
My Saabs: 04 93 arc espresso black
does anyone have the images to sabas thread? im trying to wire up a sub and i want to get the source from the front i need to know where to tap to get a good strong signal.
i <3 backroads.
i rule your internet.
Old 07-08-12
aerojon's Avatar
speakers outs of amp1..
Old 07-08-12
What plugs should i get? http://www.genuinesaab.com/catalog/p...roducts_id=775 or http://www.thepartsbin.com/catalog/?...mk=Saab&md=9-3 ( the AEM ones)
Old 08-08-12
pacotaco's Avatar
nvm think i got it
i <3 backroads.
Old 08-08-12
Nocturne's Avatar
Nocturne Nocturne is offline
My Saabs: 2004 Nocturne Blue 9-3ss Linear
It seems like:
1 is constant slow
2 is constant fast
No intermittent options like that for auto wipers. It's Auto (rain sensor), low, fast. But in the SID you can adjust the sensitivity for rain: Low>Med>High.
2004 9-3 Linear Canadian touring package.
16" 10 spoke wheels, dual Xenon, sunroof, reverse parking sensors, auto wipers, homelink auto dimming mirror, heated seats, dual climate control, block heater.
Old 08-08-12
My Saabs: 2004 9-3
I also noticed that right after I used my windshield washer fluid, I tried again and it didn't work! Is there something that I don't know?
Old 08-08-12
g12mcgov's Avatar
g12mcgov g12mcgov is offline
My Saabs: 2007 SAAB 9ł 2.0T SS
Default What windshield washer size do I buy?!?!?
What windshield wiper size do I buy?!?!?
I have tried 3 brands now from THREE different stores, each of which the salesman claimed the blades would fit but they DO not fit. Someone please help!!
I am looking for a good blade, not just an OEM-quality blade. Links/URLs to blades that FIT would be much appreciated.
From Sweden With Löv
Old 08-08-12
Don't ask me why, but I need to know where the side impact sensor is for the front passenger side. Also, are they reusable, or one time only thing?
Old 09-08-12
kevgib kevgib is offline
My Saabs: 2008 Aero TTid SS
@Sadcar - http://saabworld.net/f146/saab-9-3-a...cription-1809/
