1987 SPG project - Page 9 - SaabCentral Forums
Go Back   SaabCentral Forums > Saab C900, 1979-1993 & '94 Convertible (C=classic) > C900 Performance, Mods & Tuning > C900 Projects
C900 Projects For ongoing threads concerning classic 900 projects
Old 1st July 2012
Krizzie's Avatar
Krizzie Krizzie is offline
My Saabs: White MY91 900S Aero
If you get the regular bumpstops and put a longer bolt with a bushing of somesort in it your pretty much there.
I ordered a custom set which someone here in Holland made. But I think you can easily make them for yourself seeing how handy you are.
Here are some pics of them:
Normally you have the metal bushing between the chassis and the bumpstop
Old 1st July 2012
Malko's Avatar
Malko Malko is offline
My Saabs: 2008 Turbo X & 1987 Lime Yellow SPG
would anyone like to donate (or i can buy) 3 of these hatch shock retaining clips, i can't find them at a hardware store, auto store, or junkyard. pm me!
  #163
Old 9th July 2012
QuickOrange's Avatar
QuickOrange QuickOrange is offline
My Saabs: '92 900S, '93 900 Turbo Vert
I used a circlip on mine. Cost a couple pennies each at Home Depot, works perfect.
'93 Saab 900 Turbo Vert: New project...
'92 Saab 900 S: My first 900 and what a beauty
'90 Chevy 1500, Stepside: Ongoing project, future recipient of a 400HP LS2
'00 Kawasaki Ninja 500R
  #164
Old 12th July 2012
Malko's Avatar
more progress!!! after starting the whaletail foam surround, i have been focusing on the mechanical aspect rather than aesthetics so i can get it up to scanwest and get the last few things done to get it running and work on the interior things later. i got some tires, got 2 wheel back from the powder coater a lot of the wiring is completed including the battery tray and power/ground is complete. i checked the grounds at the front of the spg and everything works and grounds out just fine! also ended up using the circlips (thanks to quickorange)for the hatch shocks. enjoy some more pictures!
scanwest is going to sort out the rear brakes for me as well as shift linkage, bleeding the clutch and brakes, and final wiring, timing, and the initial start up! plan on dropping it off the first week of august once i button up a few more things.
after scanwest i'll bring it to get aligned to sort out the steering rack and make sure all the suspension is nice and straight for the new tires and everything
by that time i'll have it driving and slowly piece together the inside
  #165
Old 22nd July 2012
About how much paint did it take to cover the exterior? I'm trying to estimate the cost of a paint job, but I wasn't sure if a gallon would be enough.
  #166
Old 22nd July 2012
Malko's Avatar
I think I used 3 quarts of color, 2 quarts epoxy sealer, 4 quarts of clear, I used a epoxy grey green sealer coat as my base so the color covered well, I did 3 coats of color cause it was pretty light
  #167
Old 22nd July 2012
Cool, thanks! I'm looking at a nice single stage, and at this rate, I think my prep supplies are going to cost more than the paint itself.
  #168
Old 22nd July 2012
Malko's Avatar
After everything I was about 650-750 in materials at my shop prices single stage is nice though!
  #169
Old 22nd July 2012
I definitely won't end up with as nice a product as you, I just want to get it looking halfway decent and not have to worry about rust.
  #170
Old 5th August 2012
Malko's Avatar
update!!!! :
spg kit is fully fastened (minus front bumper and doors [still off] and fore most front fender panels [i need to keep them off so it clears the tow dolly] had mostly new bolts that i painted black and new speed nuts
rear and quarter glass (edges trim blacked) is in after lots of tint scraping and adhesive removal
+ battery cable from back is ran to distribution block next to shifter and the - is all grounded in the back and carries ground to the front everywhere i checked !!
tail lights are sanded down again and ready to be tinted (shaved the branding on them)
tail light housings and bumper trim are trim blacked (in satin)
new vinyl on the lower part of the hatch (will paint eventually)
painted the rear portion of the carpet
have other 2 tires will mount monday or tuesday and get it on the ground!
ordered intercooler & some install components, downpipe, silicon vacuum hose kit.
will finish the front portion of the carpet, and buy new sound deadener to replace the once coolant soaked foam
also need to scrape off the door window tint
more to come soon!!!!!!!!!
*****help, what is the order or the wiring for the lights on the hatch? there is a green, black, and red which goes where? thanks!
  #171
Old 6th August 2012
dmgb5's Avatar
dmgb5 dmgb5 is offline
dmgWarden
My Saabs: '89 900 T16Spg, '97 9000 Aero
In case you didn't figure it out yet...
ID:	30798   Click image for larger version
  #172
Old 7th August 2012
Malko's Avatar
now on the ground! hoping it will go down 3/4" -1" after the new shocks settle in and the springs and once everything is put back on. a few last things i need to wrap up before i bring it to scanwest next week so they can get it all fired up!
  #173
Old 8th August 2012
Squaab99t's Avatar
Squaab99t Squaab99t is offline
My Saabs: '89 900t 4dr'78 99t'78EMS'11 9-3 Turbo4
Default Looking awesome
You have a lot of weight you have not added back on the car. Hood, Windsheild, seats, I'd guess at 150 lbs. She will sit lower.
Love to see the car in person. We are have a dyno day Sept 1 are R&H garage. You can run, but you don't have to. You are more than welcome to come visit and cheer on your fellow enthusiast. Might have to bring some napkins for all the drool when folks check our your ride.
  #174
Old 8th August 2012
Malko's Avatar
i'll try to put something together for the 1st! i would love to drive it for the first time in a looong time! almost there gotta keep chuggin along!! i figure between the doors, windshield, spare tire & stuff, interior, fluids, hood, sunroof i'll add more than more than just 150 pounds! looking forward to start showing her off though!
  #175
Old 9th August 2012
AUSSIE900 AUSSIE900 is offline
My Saabs: 89 900 AERO, 88 900 Aero , 93 900 Aero
Default Looking Absolutely ..... AWESOME
Amazed at the job you have done to date , absolute credit to you.
U copped a bit of flack early days re color , but boy its coming together well .
Love the dark accents ( bumper inserts and tail light tints ) One very unique quality car , without being ricey or Bling ...
Top job .
Curious on the SPG panels as I am fitting some up now to a vert , did you use any edge moulding between the skirt and the panel ? Cant pick in the pictures .
  #176
Old 10th August 2012
Malko's Avatar
I did use foam between the panels and the body, I'll post some picture of it next time I take some!
But thanks for the love, some people hated the lime yellow but I love it its all coming together when all the trim and what not I did in satin is put on.
  #177
rawill's Avatar
rawill rawill is offline
My Saabs: 06 93 2.0,93 9000griffin 92 900s LPT vrt
Yes looking real good, and the colour makes a real good statement.
03 V6 Renault Laguna! 06 93 Linear 2.0t, 93 9000 griffin 2.3 St-II. 93 9000CSI na man,350,000km. 92 900 S LPT vert.
  #178
ejenner's Avatar
ejenner ejenner is offline
Banned
My Saabs: 900 Carlsson, 99t, 99 T16, 900 t16 vert
here is the progress on the motor
Missed this project. I must have been spending too much time over on the other forum (link below ) - Your car looks awesome. I think these colours which have a sort of light metalic quality like what you've chosen and the prototype SPG colour are really good for the shape of the 900 / 99.
One question, in the photo showing the transmission from the front, what is that sensor which has been screwed into the hole for the 5th gear peg and what are you going to use it for?
  #179
spg1 spg1 is offline
My Saabs: 2008 Aero 95
I was going to ask the same question. Funny, if there is something out of the norm, you pick it up right away.
  #180
Malko's Avatar
i have no idea it was out of the ordinary, it was just there when i got the car, i'll ask scanwest thursday!!!!!!!
1987 8v na 3dr SteveTheFolkie Cars for Sale - North America 9 19th October 2010 11:09 AM
My 1987 900 SteveTheFolkie C900 Workshop 1 11th April 2010 01:03 AM
For Sale: Parting out 1987 SPG lancer Parts for Sale/Wanted - North America 60 24th July 2009 09:03 AM
1987 900 turbo BABE Rally project slickdizzy C900 Projects 1 19th January 2009 09:25 PM
Uma: 1987 Saab 900T project mikewitdaspike C900 Projects 10 2nd July 2007 10:42 PM
