| Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum |
This is a topic that goes off quite well in the C900 forums so lets try it here!
I tightened the serp belt on the B202 engine in my 9K today (it's the manual-adjustment type), put some fuel in the tank, and tidied up the inside a bit including cutting off the completely collapsed fabric 'liner' from the sunroof cover. Craig.
Craig Dewick - Wollombi/Laguna, NSW, .au- Websites Flickr - 23 - Saab C900's - Saab 99's - Saab 9000's - Free non-commercial Classic Saab albums and Classic Saab forums - RIP Moose.Parts which these forums still ILLEGALLY censor any mention of in postings! |
Cheers |
Did some more testing on the freshly rebuilt engine I installed this weekend.
Unfortunately, the alternator I had bolted to it only produced 11.5v and lit the battery lamp, so I had to pull it out through the wheel well and replace it. The engine has about 3 hours on it so far, runs smoothly and doesn't leak. |
Also the dash bulbs in general are very dim, including the ACC, radio, CD player, seat heater switches, etc, but some of those are a pain to swap. The radio ones, for example - the ones with the little green covers that are soldered in place. I would love to change the whole dash to white but I just don't think it's possible, particularly with the green-tinted "conductor channels" that are in the radio.. I broke the leads from the alarm LED repairing a speaker. Was it pretty easy to fix/replace with another bulb? Cheers! |
My city lights in the high beam are LEDs as well and it's very white compared the to low beams. I'll post those pics later. |
Tried the grill mesh/screen update. Looks ok. I'll post those pictures later when on my PC not iPhone.
The grill mesh came from Home Depot and it's aluminum "gutter guard". Last edited by VT9000CSE; 02-08-12 at 09:24 PM. |
Replaced the a/c compressor, changed oil, plugs, air filter, oil filter, fuel filter, auto box oil and filter change, replaced brake fluid.
Tomorrow it's time to pull useful spares from my '96 parts car before the rest goes to the scrappy to make some space |
This was over the course of 4 days: Replaced blown engine (swapped to b235r cylinder head), auto to manual conversion, full JT 3" exhaust on my recently acquired 97 Aero
TD04 is next, that little t25 runs out of steam real quick now! |
Fitted a new pair hatchback struts, now setting up to have a look at what I need to do for replacing the front strut mounts.
Craig.
Had planned on replacing my thermostat, fixing a loose bulb in the hi-level lamp, solving some bulb issues in the instrument cluster and cleaning the carpets.
But it rained all day long. Took dog for a long walk instead.
Owned: '80 900GLe Auto 5dr/'84 99GL/'85 900t16 3dr/'86 9000t16 Own: '96 9000CSE 2.3 Auto |
Not a 9000 but I did replace a T5 ECU in a 1995 900 convertible for a fellow Saaber and I had tuned it to Stage 3 for him. Ran so much boost that it popped the BOV/Diverter valve off the intercooler to intake pipe! Really it was only a little more than 15-17 psi with a peak one time to nearly 19 psi. It was probably a loose hose clamp.
It stopped raining... temporarily. Finally sorted out my hi-level brake lamps, replaced some bulbs in the instrument cluster (and cleared out a load of gunk from behind the dash), replaced the rear anti-roll bar bushes, changed two front tyres, welded a pinhole in the exhaust, reset the handbrake cables to the rear so they actually work... and got it through the MOT test.
Phew.
Bought an aero
Ordered a new master slave radiator bushings clutch and hoses trying to be preventative |
td04 installed. Still waiting on the proper oil return, made a suitable replacement for the time being
| Tags |
| 9000, aero, repair, saab, turbo |
| Got my first Saab today | chromatica | Classic Saab 900 Workshop | 23 | 12-09-09 05:33 PM |
| Got my first Saab today! | EndlessRyd | Classic Saab 900 Workshop | 12 | 10-02-09 10:44 AM |
| Where did your Saab go today? | numbersix | Saab 9-5 Workshop | 12 | 14-07-08 06:39 PM |
| saab 9-5 on I-95 in RI today... was it you? | WhiteSummer | The Lounge | 9 | 28-03-05 09:42 AM |
| would you buy a new saab today? | tristan tumble | Saab 9-3 & NG900 Workshop | 64 | 06-03-05 06:08 PM |
