Submission For JULY'S SAAB OF THE MONTH - SaabCentral Forums
Go Back   SaabCentral Forums > Saab Of The Month > SOTM Submissions & Voting
SOTM Submissions & Voting Submit your car for voting & vote for your favorite Saab.
Old 18-07-12
grkguy89's Avatar
grkguy89 grkguy89 is offline
Moderator
My Saabs: 97 900SE, JZW Stage HX35 w/m injection
Default Submission For JULY'S SAAB OF THE MONTH
We're off schedule again...
Ill try and get this back on track
The rules are posted in the sticky in the main section for SOTM Submission & Voting
(here's the link just in case; SOTM, Rules and other need to knows.)
Open for entrants!!!! Will close on the 24th
follow this template
***EXAMPLE***
The Silver Sled (1988 900 Aero)
Specifications
Engine
Brand new Saab B202 2.0 Litre 16 valve crate engine (installed November 2010)
Rebuilt Bosch distributor
Stock Bosch electronic ignition
SPG9 AID (Advance Ignition Diaphragm) with timing at 20˚BTDC
Bougnicord spark plug leads
NGK BCP7EV plugs
Aquamist 1S water Injection using 0.9mm injector
Aquamist DDD (digital dash display) for water injection output
Crank case ventilation catch-can
Exhaust
2.5 inch from cat converter back with hi-flow racing cat
4 inch chrome semi-oval tip
Hi-flow dynomax stainless steel muffler and rear resonator
3 inch JSP stainless steel split down pipe off turbo to cat
Turbo
Mitsubishi TE-05 16G: with 16G compressor wheel with 10˚ clipped vanes, upgraded thrust and is rated as a 300HP turbo
Wastegate running 7psi base boost
Stage 2.5 SPG9 APC running to 18psi boost
Jak Stoll Performance Talon high-flow side mount intercooler
8 inch Davies Craig thermo pull fan mounted on reverse side of intercooler with manual switch inside cabin
Saab C900 1990+ aluminium turbo intercooler ducts
Stratmosphere Forge bypass valve
K&N filtercharger
Plastic intercooler top air dam
Fuel System
Bosch 3.0 BAR fuel pressure regulator
Trionic 5 34lb injectors
Jak Stoll Performance Stage 2 ECU chip
Fuel pressure gauge situated in-line on fuel rail
Suspension
Stock Saab Aero springs and shocks
Stock Saab Aero road handling kit including front and rear sway bars
Polyair inflatable air bags inside rear springs
Wheels & Tyres
16" x 6.5" Saab Super Aero rims
Goodyear Revspec Ducaro 205/50/16 tyres
Other
Stock Saab Aero factory whaletail
Saab Aero vent covers (factory colour coded silver to match duco)
AutoMeter 30"hg to 30psi boost guage
AutoMeter air/fuel ratio guage
Saab factory rear decor panel
SaabSavior short shifter
Saab Momo leather steering wheel
3.5mm blue silicon vacuum hose
Saab Aero original Alpine surround sound 5 speaker stereo
Aero kit factory colour coded silver to match duco
Output
Estimated 190kW (250hp) at front wheels (need to do another dyno once new crate engine is run in)
1 PICTURE!!!!
Christos (VA saab meet pm me?) JZW Tuned Stage 7
http://www.eurocarswmbg.com/
Old 21-07-12
greenydsm greenydsm is offline
My Saabs: 6spd Vector
2003 Saab 9-3 Vector 6spd
Specifications
Engine
Stock 2.0T
Spec stage 3 clutch and flywheel
40$ Intake
Exhaust
Obx 3" down pipe to a full 3" exhaust
Turbo
Fmic with 2.5" hard piping
Forge bov
Mangement
Jzw stage 3 tune
Fuel System
Stock
Suspension
d2 coilovers
Wheels & Tires
Forgestar f14 215/35-19 Continental Extreme Contact DWS
Other
Plasti dipped mirrors, grill, trim pieces, door handles
Wideband o2 and Boost gauge on A pillar.
Roof spoiler
20% tint
Headlight and foglight Lamix tint
All orange bulbs have been swapped over to clear
Output
250+? Needs to hit the dyno
Jzw Stage 3, Forge Bov
3" Turboback Exhaust
CX fmic w/ hard piping
d2 Coils
Old 23-07-12
88saab900s's Avatar
88saab900s 88saab900s is offline
My Saabs: 1990 talladega SPG
1990 Talladega SPG
Mods
Engine
2.0L 16v Turbo 5spd.
Blue series injectors
3.0 bar
Red box apc
High pressure bypass valve
18 psi wastegate
CAI
Fuel chip
Performance wires
FMIC
15+ psi of boost
Exhaust
Catless starla exhaust
Suspension
Lowering springs
Bilstine shocks
Interior
Black leather, plaid red/white/black door inserts and shifter boot.
Boost gauge on the A-pillar
Full sound system
Exterior
Talladega Red SPG
Window louvers
Blacked out front grill
Old 24-07-12
Cark's Avatar
Cark Cark is offline
My Saabs: 03 Aero Wagon 5 spd, 85 turbo 3dr 5 spd
The 85
1985 900 turbo
3rd owner
103k original documented miles, New Hampshire car it's whole life, however it has never seen snow/salt.
Mostly stock with some neat dealer options:
-Louvers
-Inca wheels
-Rain Guards
-Center Armrest
to name a few
Engine had a new head gasket done @ 101k miles and is getting converted to Trionic 5 in 2 weeks
I just finished swapping the hubs/knuckles/rear axle to 88+ components. It rides on SPG springs with 98 CSE super aeros. 205/50/16 Falken's brand new.
And oh yeah, in case you missed it, I just bought it a few months ago for $500
Old 05-08-12
2.3LiterCivicBeater's Avatar
2.3LiterCivicBeater 2.3LiterCivicBeater is offline
My Saabs: '01 9⁵ JZW stg.3 ,'91 900T,'92 900
ooooooh stickers
Old 16-08-12
Cark's Avatar
so.... crickets here... this is what I get for bucking up and submitting my 85 this month
Submission For JUNE'S SAAB OF THE MONTH grkguy89 SOTM Submissions & Voting 29 24-07-12 06:58 PM
Submission For APRIL'S SAAB OF THE MONTH grkguy89 SOTM Submissions & Voting 15 18-04-12 12:22 AM
Submission For JANUARY'S SAAB OF THE MONTH grkguy89 SOTM Submissions & Voting 11 18-01-12 03:17 PM
Submission for NOVEMBER'S Saab Of The Month grkguy89 SOTM Submissions & Voting 15 15-11-11 03:21 PM
Submission for OCTOBER'S Saab Of The Month grkguy89 SOTM Submissions & Voting 15 27-09-11 12:02 AM
