My beloved Saab 900 is overheating - SaabCentral Forums
Go Back   SaabCentral Forums > Classic Saab 900, 1979-1993 & 94 Convertible > Classic Saab 900 Workshop
Classic Saab 900 Workshop Classic Saab 900 (1979-1994) Technical Forum.
Old 10-07-12
steiraug steiraug is offline
My Saabs: 1987 Saab 900 Turbo Convertible
Default My beloved Saab 900 is overheating
hello, i am new to the forum, i just got a nice Saab 1987 a month ago and in the past week i noticed that the gauge is close to the red mark ,it does overheat especially in traffic stop and go , i checked the extension coolant tank and it is full, the hoses are very very hot, when i get home the fans keeps running for like 3 minutes then stop, i asked the guy who sold it to me if it overheats, he told me it did at one point and it was the thermostat , and he replaced it. i did not notice any coolant leak..the amount in the tank stays the same. any help would be greatly appreciated, i will be devastated if i blow the head.
Old 11-07-12
Rodentmaster's Avatar
Rodentmaster Rodentmaster is offline
My Saabs: Rip:'86 EMS Now? 2x 93 2.1 5dr & Vert
Two items to suspect........
1. Radiator - (best to replace with new item) .....lower radiator hose near air filter housing........? is it hot enough to prevent you touching it? as in just as hot as the top hose? If so, the radiator would look to be not up to it anymore.
Make sure there is no blockage of air from the front and in between the A/C condesor and the radiator.
2. Thermostat - let's say he did change it - did he put the right one in? lots of thermostats look identical and phyiscally fit in the housing but aren't not entirely compatible. or he could be telling porkies about changing it at all?......
If the top and bottom hoses are equally hot to touch, coolant is moving to and from the radiator.......thermostat could be ok.
Primarily, the radiator is the first place to start.
It's sole job is to remove heat from the coolant - it looks like this attribute is not being satisfied.
Woah! Don't expect men to talk to your face if you patronise that establishment!
RodentMaster, post links responsibly!
Eat the Pudding!
ODE to the N\A
"I have not TURBINE to compress my buttocks, O lord,
Pity will be thine when thoust can crap on with boost.
We of the 'N\A - N\A' knowst nil of the pulling glory,
Yea, to post, thy blight the day of those who pressurise their pipes,
Alas, suck be mine that my chariot breathes,
Strike me down for mine is an unworthy existance"
Old 11-07-12
S900t8v's Avatar
S900t8v S900t8v is online now
My Saabs: Trionic 5.5 1984 900t 8v
water pump may have failed.
The pressed on impeller separates from the shaft on cheapos and the impeller corrodes away on really cheap ones.
Old 11-07-12
peva peva is offline
My Saabs: '94 T16 Ruby 3dr, '93 T16 Ruby Vert.
I agree with all the above. The radiator is probably clogged, which you cannot cure by flushing. If it is at fault you will need to replace it. As a quick check for circulation, ie water pump, observe the water flow across the top of the water reservoir on a warm engine with the reservoir cap removed. This is best observed when you rev the engine. Take care removing the cap if the engine is very hot. The system will be under pressure. Best to let it cool a bit.
PS If you do see this flow it confirms that the thermostat is open. Also bear in mind that if the needle is still on the gauge, although high, the engine is not overheating.
Old 11-07-12
16saabs 16saabs is offline
My Saabs: 2x LPT convertible's, 1 x 900 SE
don't know if this is possible but the sensor may have'failed' so it sends the incorrect message?? but check whats been said above and repot back as there's always plenty of help on here.
22saabs
Old 11-07-12
Jim Mesthene Jim Mesthene is offline
Originally Posted by steiraug View Post
... i noticed that the gauge is close to the red mark ..in traffic stop and go.
....... when i get home the fans keeps running for like 3 minutes then stop.... i did not notice any coolant leak..the amount in the tank stays the same.
All of that could be entirely normal.
Do both fans run?
Corporations are people! If you prick them, do they not bleed? If you tickle them, do they not laugh? If you poison them, do they not die?
Old 11-07-12
jerdobi jerdobi is offline
My Saabs: 1989 900S 4-Door NA
Default The good, bad an ugly.
From cheapest to most ugly....
Good: thermostat replacement or needing air purged out
Bad: radiator cleaned (if metal radiator clean and KEEP, if plastic, replace). Try turning on heater full; if cools down likely radiator plugged.
Ugly: head gasket failed is finally likely cause
Old 11-07-12
scantar's Avatar
scantar scantar is offline
My Saabs: 1992 vert turbo, 1984 3 door turbo
A radiiator is so cheap for our cars (I just bought one for $120 delivered!) that it's just silly to not replace it. One of the easiest things to do on these cars too.
Originally Posted by bimmerjeeper View Post
So what you're saying is that I need to find a way to make my rod longer?
1992 Turbo 'vert, 1984 Turbo 3 door
Old 12-07-12
The Saab cooling system does not need purging. It does it all by itself. That is what the very small hose from LHS top of rad to reservoir does. Just keep the reservoir topped up and the rest is automatic.
Old 12-07-12
jameschong's Avatar
jameschong jameschong is offline
My Saabs: '90 LPT to FPT, auto to 5sp type 8
I thought that's what the nipple next to the stat was meant to do - bleed the air out?
"I will never join a club that accepts people like me as members..."
Old 13-07-12
Yes, some air will come out, but if left it will all come out on it's own.
Having to Sell Your Beloved Saab saabhutter The Lounge 0 28-07-10 01:07 AM
My beloved 2002 went up in flames :-( Ld_rider Saab 9-3 & NG900 Workshop 12 28-06-10 04:00 PM
My beloved 1990 T16s ears The Lounge 2 12-09-07 01:49 PM
My beloved one! TraSh Classic Saab 900 Workshop 11 27-08-05 03:05 PM
