Head Gasket or DIC? - SaabCentral Forums
Old 30th June 2012
jimfellows jimfellows is offline
My Saabs: 2000 9-5 SE V6
Default Head Gasket or DIC?
I have a 2000 9-5 SE with the 3 liter V-6. It has 115000 mile on it and is well maintainted. It did something very strange this week. I was at a stop light and all of a sudden it stated skipping or miss firing. I started moving and drove it about a hlf mile and pulled over and turned it off. I have an OBI II reader and checked, but there were no codes. I started it up and it ran fine. I have drivien it a few more miles and have had no issues. I was planning on changing the oil today and decide to change the spark plugs as well as it is around 27,000 miles since I changes them and it may have been the issue. I pulled the front DIC and sicovered oil in all three spark plug wells. There was the mosit in the one closest to the belt end of the engine and the least on the one twards the transmission. The rear set were clean and dry. The front DIC fialed at 88,000 miles and I replaced both at that time. I cleaned out the oil and replaced the plugs and swapped out the DIC for the "old" good one I saved. Is this a DIC or do I have a head gaskit going on my car? The coolent is clean, showing no oil.
Thanks,
Jim Fellows.
Old 30th June 2012
N.E. Swede N.E. Swede is offline
My Saabs: 4 c900, 97 9k Aero, 02 9-5 aero
It's the valve cover (gasket) leaking oil into the spark plug tubes. Easy to change the front one
Old 1st July 2012
To replace, is jut pull the four bolst on the cover and replace the gasket?
Jim
Old 1st July 2012
TankTak TankTak is offline
My Saabs: Elskerinne..'02 Saab 9-5 HBSaabs stage 3
Jim
unplug the Di, remove it, forgot how many there are but remove all the bolts exterior of the valve cover as well as those within the chanber where the DI resides and pull up on the valve cover. When I removed mine I had to give it a wack with a rubber mallet to break it free, try not to stick or do anything that can ruin or damage the mating surface where the gasket sits.
Take a look at this tsb for torque specs and order of installation, its towards the bottom
http://www.townsendimports.com/Saab_..._1704_utg2.PDF
Old 1st July 2012
Jim
I believe there are 8 bolts total (once the dic is off). Make sure you get a valve cover gasket "kit". Each bolt has a grommet, and there are 3 spark plug tube seals. I use a dab of anaerobic sealer (permatex/loctite 518) to hold the grommets in the cover when installing
Old 1st July 2012
Thanks for the info, but the link is to a 4 cylender cover, I have the 6 cylinder.
Jim
Old 1st July 2012
Jim
sorry I read too fast and missed that part
Old 1st July 2012
Thanks for the info. Saab USA has the kit istock. I will try my two local dealers first to see if they have them.
Jim
Old 2nd July 2012
I repalced the valve gasket today. It took a an hour and a half from start to finish. Not a bad project. Thanks for all the help.
Jim Fellows
Doing a 94-02 4cyl head gasket? read this, mine leaked with 100% flat and new gasket jimbo81587 NG900 & OG9-3 Workshop 0 3rd July 2011 12:03 AM
HELP: Head gasket/Head replacement Complete - NOW COOLANT LEAK!!! NEED HELP dougwentzel NG900 & OG9-3 Workshop 5 9th September 2010 10:23 PM
Which torque spec for head when replacing head gasket? 98 2.0L SE 16V twilightcall NG900 & OG9-3 Workshop 3 31st March 2008 02:02 PM
doing a head gasket on my 94 aero need head bolt tourqe spec 1quick2.0t 9000 Workshop 1 1st March 2004 05:34 PM
Blown head gasket or cracked head??? please help azSaabTuner C900 Performance, Mods & Tuning 1 19th May 2003 02:15 AM
