| Saab 9-5 Workshop Saab 9-5 Workshop (1997 to 2010) Technical Forum |
Currently outside working on my car, it hasn't started for a month. Anyone have a diagram of the wiring of the car? It is acting as if it cannot connect to the ECU, the car does start occasionally for just a second then dies. This leads me to believe there is a bad connection or something.
Please help me find a wiring diagram, I can't find one! |
ECU is the last thing i would look at for that kind of problem
So where would you suggest looking?
hi there i no this was posted a while ago but did you get to the bottom of this problem as i am experiencing the very same problem
Hi Bob,
If you are experiencing this same problem it sounds like the throttle body has gone into limp home mode. I would try to reset it and see if that makes a difference. I would also look for cracked hoses and vacuum leaks which could have made it go into limp home in the first place. |
The problem im experencing is it ran ok parked it up and now it wont start. It will turn over and only start and run for a second when i reset fuse 17. I have changed mains relay,di,cps,had ecu checked,and all earths. Ive done the usual voltage checks and everything seems fine. Starting to really confuse me
| Wiring Diagram | snoborderphx | Saab 9-3 & NG900 Workshop | 2 | 16-06-10 03:22 PM |
| Wiring Diagram for 9-3? | SLIVER23 | Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop | 0 | 26-03-09 11:32 AM |
| Need a wiring diagram | valbowski1980 | Saab 9000 Workshop | 4 | 25-10-05 11:24 PM |
| wiring diagram | jdiddy | Saab 9-3 & NG900 Performance, Mods & Tuning | 1 | 11-06-04 04:21 PM |
| wiring diagram.... | saabkid37 | Saab 9000 Workshop | 1 | 04-04-04 11:43 AM |
