Clutch replacment - SaabCentral Forums
Go Back   SaabCentral Forums > Saab NG900, 1994-1998 9-3, 1999-2002 & 03 Convertible > Saab 9-3 & NG900 Performance, Mods & Tuning
Saab 9-3 & NG900 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9-3 98'-02' & NG900
Old 19-06-12
Demusku Demusku is offline
My Saabs: 97 900se 2L T28 Stg3,09 9-3 2.0 5/6 spds
Default Clutch replacment
Well my clutch is slipping after half throttle, 10lbs boost. In the next year i plan on doing the injectors and fuel pump and im gonna push her to the max on that setup till the engine blows. I drive pretty hard usually aswell.
Ive read through alot of clutch stuff on here and im pretty much down to trying a clutch from clutchnet or just going with the viggen clutch and pressure plate?
Ive seen good and bad about clutchnet and im not afraid to try something out. Although the viggen clutch ive seen pretty much no complaints from.
Im leaning more towards the viggen but part of me wants to try out something different.
http://www.clutchnet.com/clutches?page=shop.product_details&flypage=flypage .pbv.v2.tpl&product_id=5468&category_id=3499
Old 20-06-12
bogan's Avatar
bogan bogan is offline
My Saabs: 97 900se Talladega stage 5
What stage is your car at ?
B.L.T.H.....Brake late Turn hard
Old 20-06-12
Paul8ex Paul8ex is offline
My Saabs: VIGGEN
Yes knowing what stage your at would help. I personally have used a clutchnet stage 3 setup on my stage 4 Viggen and i would never go back to it or recommend it to anyone. The clutch was no where near able to hold the power they claim to be rated for.
Old 20-06-12
Fox Fader's Avatar
Fox Fader Fox Fader is offline
My Saabs: '98 900SE Manual
So what are you using now? I'm trying to prepare myself and car for more power. I'm going straight to stage 3.
Old 20-06-12
grkguy89's Avatar
grkguy89 grkguy89 is offline
Moderator
My Saabs: 97 900SE, JZW Stage HX35 w/m injection
something doesnt sound right there.... ive got a clutchnet stage 3 on my stage 6 gt30 and it holds just fine (and thats 400whp territory)
it's possible the clutch glazed as the break in process is slightly more sensitive than a factory clutch
you'll be fine with a viggen clutch kit
no need to overkill
Christos (VA saab meet pm me?) JZW Tuned Stage 7
http://www.eurocarswmbg.com/
Old 20-06-12
My Saabs: VIGGEN
No it didn't glaze I have the clutch sitting in a box at home and it's just shot. Ate through the friction material almost all the way to the rivits it's bad. I now run the spec stage 3+ clutch with was very exspensive but has been awesome so far a little bit harsher ingagment but I daily drive the car and it's fine. I agree for a stage 3 2.0 the Viggen kit should be good.
Another thing I think about is maybe I got a defective unit or maybe I was send a lower stage by mistake cuz when I got it from gs it was not in a clutchnet box.
Old 20-06-12
grkguy89's Avatar
Moderator
that is very likely, as ive read others having problems from buying clutchnet discs from GS
IIRC one guy received a disc that looked used from them
Old 20-06-12
bogan's Avatar
I think the viggen clutch disk will hold stages 1-4 no problem. But I also know people who have a viggen disk in 5-6 stage cars.
I have a viggen disk in my stage 5 now and it was holding but is slipping. I think I rushed the break-in procedure. If I had of been a bit easier with the break-in ,who knows it may of held.
I have been told a Viggen disk is usually only good to around 300 whp.
I have a clutchnet 6 puck sitting in my bench, ready to go in. I bought my clutchnet disk from clutchnet .com, direct.
The viggen disk will hold most cars.
Old 20-06-12
Fox Fader's Avatar
no need to overkill
Are you saying I can go to my local parts store and just ask for a clutch kit for say a 2000 2.3 turbo?
Old 21-06-12
bogan's Avatar
You want a 99-02 Viggen clutch kit like this http://www.partsforsaabs.com/product...oducts_id=3698.
Make sure it is "Sachs" brand.
I just checked europarts and they have no pressure plates
Old 21-06-12
Oh my fault i thought i put my stage under my name up in the corner. I have it at stg 3 right now, T28 turbo. After reading on here im sure the viggen will do fine im more concerned about when i do the fuel injectors and pump. Although Im not convinced even at that point ill need something stronger but i will need something that can handle a bit of abuse. I really like to drive this car hard. I just bought a 2009 9-3 today so ill definitely be driving the 900 hard now.
It is also possible that next summer im gonna do some part swapping from my car to my friends and tryin bump my car up a whole bunch. I want to aim for the 450hp range but i havent done much research past what ive currently done. Im not really sure what itll take to achieve that though it seems i should be looking ahead at that so i dont just burn up a year old clutch.
Theres just to many choices when you go digging and i like to talk these things out before i make a decision.
Old 21-06-12
bogan's Avatar
When I had a stage 3 in my car the standard clutch was fine. Don't worry about injectors and pumps till you get to stage 5.
Old 21-06-12
Fox Fader's Avatar
Got it guys. Thanks
Old 22-06-12
Im hoping by the end of next summer im in that range.
What about this: If i go with the viggen clutch i can put the aluminum flywheel on for not much more than if i bought just the clutchnet clutch. Now is the aluminum flywheel worth putting on? Ive read pretty mixed feedback on the worthness of adding one. The way i see it, Im doing the entire suspension at the same time as doing this clutch and i want to replace/change everything that involves removing the transmission while im in there.
SO Im going to go with the viggen clutch. Im kinda figuring by the time i need a stronger clutch ill be doing the transmission anyway. I guess i should mention I have big dreams for this car.
Old 12-07-12
I cant seem to find the viggen clutch kit in stock anywhere. Does anyone know somewhere im not looking? or if anyone has the part numbers that might help. i found a post with them before but i cant seem to locate it atm.
Hard Clutch pedal after replacment? 900 aero Classic Saab 900 Workshop 0 19-11-09 04:08 PM
"97" Clutch replacment.... HELP &&&&&&&& swede901 Saab 9-3 & NG900 Workshop 4 29-10-08 11:21 AM
Pad replacment Flyboy Saab 9-3 & NG900 Workshop 2 14-04-08 05:16 PM
clutch slave cyl. replacment, ive got a few questions jbvw96 Classic Saab 900 Workshop 2 17-07-04 04:51 PM
Replacment Battery rockin 9-5 Saab 9-5 Workshop 4 05-05-04 02:31 PM
