Replacing inner CV boot on Sonett V4 - SaabCentral Forums
Go Back   SaabCentral Forums > Saab Classics - 92, 93, 95, 96 & Sonett > 92, 93, 95, 96 & Sonett Workshop - covers *only* vintage models (1949-1980) prior to the 99
92, 93, 95, 96 & Sonett Workshop - covers *only* vintage models (1949-1980) prior to the 99 92, 93, 95, 96 & Sonett Technical Forum Covers *only* vintage models (1949-1980) prior to the 99
Old 1st June 2012
SilentSaab SilentSaab is offline
Default Replacing inner CV boot on Sonett V4
Hi!
I have noticed that the left inner CV boot on my Sonett V4 has two small cracks (3-4mm) where the grease leaks out when it gets hot. I assume the boot must be replaced and that patching the cracks is a hopeless task?
So is there a recommended procedure for replacing the boot? What needs to be disassembled in order to get the old boot off and a new one on?
Thanks
Old 20th June 2012
earthworm's Avatar
earthworm earthworm is offline
Saab Sage!
My Saabs: '96 900S, Automatic with 148K miles, blu
Originally Posted by SilentSaab View Post
Hi!
Thanks
It has been a while - 50 years -
If we have the bi-pod inner driver, a good new soft boot can be persuaded to stretch over the driver - I have done this more than once - and one I did tear a boot ($3 down the drain)..
So much for short cuts.
You will have to remove the axle assembly from the outer CV joint - this requires a "ring squeezer" - a special Saab tool, maybe Saab only, I do not know...That is the method I used - long ago..I think it requires 2 special tools...I may have one...
Now, today, BION, I repaired a inner boot that was leaking the moly-grease thru a crack in the rubber....4-5 years ago, and she is still fairly clean and dry !
I would not recommend doing this(economics), but the new boot was $40 and not available anyway..
This task on the '96 900..
The earthworm
'96 900S, Automatic
Those who think in the past will have no future.
173K miles in the good ole USA
Old 9th July 2012
Thank you for your reply. I ended up using a local workshop this time, but thanks for your advices, will save them for next time.
Need help replacing the SportWagon hatch / boot emblem cleveland_saab 9-5 Workshop 21 6th January 2016 09:17 AM
Replacing outer CV boot epsilon93 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 3 17th June 2011 02:27 AM
Replacing the Outer CV Joint Boot? 2 man job? princeben C900 Workshop 10 18th April 2010 03:06 PM
Replacing left inner CV boot whiteblur 9-5 Workshop 10 16th March 2010 12:24 PM
E-Brake Boot Needs Replacing KFirebird 9-5 Workshop 3 6th July 2008 06:48 PM
