93 vert backseat removal - SaabCentral Forums
Go Back   SaabCentral Forums > Classic Saab 900, 1979-1993 & 94 Convertible > Classic Saab 900 Workshop
Classic Saab 900 Workshop Classic Saab 900 (1979-1994) Technical Forum.
Old 16-06-12
kplantc900 kplantc900 is offline
My Saabs: 93 Turbo Convertible
Default 93 vert backseat removal
Another odd question? How do you remove the bottom part of the rear backseat on my 93 vert?
Old 16-06-12
scantar's Avatar
scantar scantar is offline
My Saabs: 1992 vert turbo, 1984 3 door turbo
Should just come up at the front with a good sharp tug upward, then pull it towards you.
[edit] some models had a couple small bolts under the leading edge of the seat...not sure if that was older or newer (my 92 lifts up) but check before you dislocate your shoulder
Originally Posted by bimmerjeeper View Post
So what you're saying is that I need to find a way to make my rod longer?
1992 Turbo 'vert, 1984 Turbo 3 door
Old 16-06-12
16saabs 16saabs is offline
My Saabs: 2x LPT convertible's, 1 x 900 SE
and he means a good tug 89 I think was the change over yr
22saabs
Old 16-06-12
jameschong's Avatar
jameschong jameschong is offline
My Saabs: '90 LPT to FPT, auto to 5sp type 8
Pretty sure there aren't any bolts.
It's a wooden base, with two holes on the leading edge which fit over corresponding metal tabs that also secured the edge of the carpeting.
Sharp tug upwards needed.
"I will never join a club that accepts people like me as members..."
Old 16-06-12
anjum anjum is online now
My Saabs: Saab c900 vert 1992, Jaguar XJS 1992 4L
A good tug should work, if it doesn't you can apply a lever under the wood above the carpet. it's got fixing points at either end a little way in from the edges.
Old 16-06-12
Got it. Quick tug and each side clip comes up
Speaker removal 95 900SE Vert - fun, games, and breaking stuff.(with pics!) wvcruffler Saab 9-3 & NG900 Workshop 5 20-01-11 12:47 AM
Backseat Rattle Jay_l_a Saab 9-3 Sports Saloon/Sedan, Combi & Convertible Workshop 10 21-11-09 06:03 PM
Onstar removal from 02 Vert GaryG Saab 9-3 & NG900 Workshop 0 17-04-09 01:00 PM
Removal/refitting GM900 vert side windows Jim Saab 9-3 & NG900 Workshop 0 20-04-05 07:22 AM
Replacement for backseat ashtray? Marlowe Classic Saab 900 Workshop 7 25-09-02 12:41 PM
