92 900 vert removing rear seat-- - SaabCentral Forums
Go Back   SaabCentral Forums > Classic Saab 900, 1979-1993 & 94 Convertible > Classic Saab 900 Workshop
Classic Saab 900 Workshop Classic Saab 900 (1979-1994) Technical Forum.
Old 28-04-12
SAABChadd's Avatar
SAABChadd SAABChadd is offline
My Saabs: 92 900T Vert Scarabe/Tan
Default 92 900 vert removing rear seat--
the bentley says a few bolts and its out but i feel with my hand and no dice, carpet will not peel back, like pulling teeth kinda, trying route some new wires for battery relocation and woofer
i dont want to rip carpet but i cant find any bolts, any help would be great!!
Old 28-04-12
scantar's Avatar
scantar scantar is offline
My Saabs: 1992 vert turbo, 1984 3 door turbo
The seat base comes out with a sharp tug up and then a pull forward. Once you've got the seatpad out, you'll see a few bolts holding the back to the rear "bulkhead."
Originally Posted by bimmerjeeper View Post
So what you're saying is that I need to find a way to make my rod longer?
1992 Turbo 'vert, 1984 Turbo 3 door
Old 28-04-12
Rodentmaster's Avatar
Rodentmaster Rodentmaster is offline
My Saabs: Rip:'86 EMS Now? 2x 93 2.1 5dr & Vert
With mine, you just grab the lower front edge of the lower seat base, say with hands a metre apart..........and lift.
The seat is held in by clips in the base clasping the two tongues on the cross frame of the car..........no bolts.
The rear Upper is held in with bolts at the bottom and in the back behind the head rests.
Woah! Don't expect men to talk to your face if you patronise that establishment!
RodentMaster, post links responsibly!
Eat the Pudding!
ODE to the N\A
"I have not TURBINE to compress my buttocks, O lord,
Pity will be thine when thoust can crap on with boost.
We of the 'N\A - N\A' knowst nil of the pulling glory,
Yea, to post, thy blight the day of those who pressurise their pipes,
Alas, suck be mine that my chariot breathes,
Strike me down for mine is an unworthy existance"
Old 28-04-12
bobsverts bobsverts is offline
My Saabs: 1990 Turbo Vert, 1992 900S Vert
Default '92 vert seat removal
On the rear seat bottom, look under the lip on the front edge of the seat. Some verts have several screws that attach the seat bottom to the frame. Remove these screws and the seat bottom slides forward and comes out easily. To remove the rear seat back, remove the 2 17mm bolts at the bottom of the seat back and then look for two vertical slits in the plastic liner in the well where the convertible top goes. The two slits are behind the head rests. Inside the slits are 10mm bolts. Remove these 2 10mm bolts. Then remove the two seat belt plastic covers - one on each side. Then lift the seat back up and out of the car.
Old 28-04-12
anjum anjum is offline
My Saabs: Saab c900 vert 1992, Jaguar XJS 1992 4L
Mine's a 92 vert and the seat base just pulls up at the front, no bolts. Good tug needed though. AFAIK the later verts were like this.
Old 29-04-12
crwchf01 crwchf01 is offline
My Saabs: Menagerie of 14 and climbing
Seat bases- three types as far as I can find 90 and later verts- snap fasteners that you pull straight up, then forward. It appears that the 88-89 cars used a hex head bolts that had to removed, and earlier used screws. All hatchbacks I have run across to date have the latch in the back on a pull tab, then forward and rotate.
It's too late for blind faith and ignorance.... gotta get a bigger hammer.
Old 29-04-12
SAABChadd's Avatar
Default Success!
tugged the bottom seat out, found the 2x10mm behind the slits, pulled the 2x17mm, the whole thing is out, and ready for new wiring, thanks everyone!
Removing rear interior side panels and rear seat in 9-3 Convertible naenyc Saab 9-3 & NG900 Workshop 4 26-07-12 12:18 AM
'vert rear seat lock ZaphodB Saab 9-3 & NG900 Workshop 5 28-04-12 09:48 AM
Wanted: UPPER Rear Spring Seat 00 Vert 9-3 Satinsax Parts for Sale/Wanted - North America 1 18-08-10 10:30 AM
Help required - removing rear seat cushion aerobar900 Classic Saab 900 Workshop 4 03-11-06 06:01 PM
Removing the rear seat.(saab-kins?) G96nt Saab 9-3 & NG900 Performance, Mods & Tuning 13 15-04-05 06:13 PM
