Wheel offset? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab C900, 1979-1993 & '94 Convertible (C=classic) > C900 Workshop
C900 Workshop Classic 900 (1979-1993 & '94 Convertible) Technical Forum.
Old 27th January 2011
Technics's Avatar
Technics Technics is offline
My Saabs: 93 Turbo Vert
Default Wheel offset?
Is the wheel offset on the stock 15" 3 spoke the same as the 16" Super Aero wheel's? And what would that offset be? Thanks in advance, Mike
SpecialTool's Avatar
SpecialTool SpecialTool is offline
My Saabs: '88 Aero, '88 vert
The Super Aero is a wider wheel, so will have a smaller offset.
Whale oil beef hooked
Technics's Avatar
You can have the same offset w/a wider rim it all boils down to inner clearance does'nt it i.e calipers and such?
My other car has 565hp 1950ft lbs of torque and gets 5 mpg on a good day..........
anjum anjum is offline
My Saabs: C900 vert white 92, c900 vert 92 yellow
Are you worried about fit or handling or clearance to brake calipers etc or just interested.
I don't know what the offset is but they work on the c900 as do the Carlssons and every other four studded 9000 wheel.
The only issue AFAIK is with the the wider tyres hitting the rear arches especially if you've got lowering or sagging springs.
They also give a more aggressive look to the c900 which I like, I've got 205/50/16s on my Carlssons.
Technics's Avatar
I don't remember where I was going w/ it too many cup's(Scotch) I want the widest profile I can get w/o crushing the arches of my 93' turbo vert,on Aero wheels.Can I push it to 215/45/16,225/40/16? I also know there's tire fitment references everywhere but first person is better. I might also run my Aeros on the rear and my stock 3 spoke's on the front. I know 16''on the rear 15'' on the front taboo,but I think It would look OK will post pic's of the the car. If I do It and when my son shows me how to. Sorry for rambling....Mike
vsfoxe's Avatar
vsfoxe vsfoxe is offline
My Saabs: 90 SPG, 86 Airflow, 91 SE, 92T, 99 9-5SE
Okay, I can't answer ANY of your legitimate questions! My red '90 SPG has Aero (not Super Aero) wheels. I put 205/45-16 tires on to avoid all rubbing problems, and they have never rubbed. So maybe (?) the 215 might be okay. In my reading I was told that the Aero (16") and Super Aero (16") had the same offset as each other, but no reference to the 3-spoke SPG 15" wheels. BUT - I just went to my basement stock, and compared a Super Aero to an SPG rim. Both inner beads look to have the same profile. With the inner bead sitting on my concrete floor, both rims appear to have the SAME offset, so I'll go out on a sapling-size limb here and say that they all have the same offset. I think.....? Vern
Old 29th January 2011
c900's Avatar
c900 c900 is offline
My Saabs: 81 8V 900T, 91 2.1 900i, 90 9k 2.0 Carly
I am sort of tackling this from the point of view of looking at off-road suitable tyres to go on my 89 900i (or the 1991 2.1 car I have just bought which has a blown HG - so the price was cheap!).
My main issue is that good off-road tyres have a significantly bigger rolling diameter than standard 195/60R15's. I believe that super-aero wheels with the standard tyres (on my 9k carlsson they are 205/50R16's) fit without any problem on any 1988+ C900.
Two things I have noticed when trying to fit up a set of aftermarket 4 x 108 wheels which bigger (215/60R15) tyres was that the offset of the aftermarket wheels is wrong and the actual sidewall width of the tyres both create problems with mounting that I could cure with some nice (but expensive, and in Ozzieland very illegal!) H&R or similar spacers.
For regular on-road driving I don't think there is going to be too much hassle with tyres hitting wheel arches but the wheel spaces aren't very large on a classic 900 so providing you get the tyres clearing the shocks and springs on the suspension (by getting the offset right), you still can't have really chunky tyres if you'll do any driving that isn't on nice smooth road all the time.
Craig.
Craig Dewick - Somewhere in Oz -
Flux Capacitor Engineer at Mr Fusion - 1981 8V 900T, 1990 9k 2.0 Carlsson, 1992 2.1 900i - RIP Moose.Parts
Old 2nd January 2012
socal1200r's Avatar
socal1200r socal1200r is offline
My Saabs: 1991 Saab 900 turbo convertible, AT
So on my '91 c900 t16 'vert, are the stock wheels 15x6, 4x108 bolt pattern, but what's the backspacing?
I'm finding that apparently there aren't too many other 15" diameter 4x108 wheels from other cars that will work. I think this is due primarily to the backspacing. The other wheels have backspacing ranging from 35 and higher, and apparently this won't work. For example, I did a search on eBay, and filtered the search to 15" diameter wheels with 4x108 bolt pattern. There are some nice looking stock wheels from other cars, but when you do the sizing calculator, they won't work on my Saab. Since the diameter and bolt pattern is the same as what I have now, I have to assume it's because of the backspacing being too wide (i.e. high number)?
So besides other Saab 4-lug wheels, are there other stock wheels from another car manufacturer that will work on a c900 (i.e. Volvo, Audi, etc)?
1991 Saab 900 turbo convertible, AT, black top, red body, gray interior (RIP 09/12/2012)
Southeast VA, USA
Saab Junkie's Avatar
Saab Junkie Saab Junkie is offline
My Saabs: 1990 SPG, 1991 MCY SE, 1993 C900 Sedan
The 16" Saab aero and super aero wheels have 27 mm backspacing, standard C900 wheels have 40 mm backspacing. So aero and super aeros stick out further, in addition to being an inch wider. The outer rear arch (the left on my C900) can rub. I centered my rear axle to solve this.
Some small fords (new Focus I think) have 108x4 bolt pattters, and here is a link to a more complete list:
http://forums.focaljet.com/tire-rack...8-pattern.html
Old 5th January 2012
gregk gregk is online now
My Saabs: 2006 9-5 SportCombi, 1999 9-5
You also need to find rims with center bore big enough to fit the hubs. Looking at the chart the Focus center bore is 63.4 mm and the Saab is 65.1 mm so factory Focus rims probably wouldn't't fit but many aftermarket rims come with bigger center bores. Also some Saabs use 14mm lug bolts which won't go through the bolt holes on some rims (can be solved by using 14mm to 12mm stud conversion kit).
http://www.ringer-racing.com/product.sc?productId=65
Old 6th January 2012
socal1200r's Avatar
Yikes, forgot about the center bore measurement! That' the same issue I had with trying to fit different factory wheels on my '89 Montero. Some Chevys have the same bolt pattern (6x5.5), but the center opening is too small. Found some Toyota alloy wheels that work just fine.
So it sounds to me like I should stick with Saab wheels from a different model. I have what I think are called the 15-hole rims, and HATE keeping them clean. Would be MUCH easier to get something like those 3-bladed Saab rims, but only if they're 15", at least the same width, or maybe even just a tad wider. I'll probably replace the tires I have on there now with 215/60-15s sometime this year, so we'll see if I've come to accept those 15-hole rims by then, lol!
Southeast VA, USA
Wheel Offset Soks NG900 & OG9-3 Performance, Mods & Tuning 5 22nd August 2008 03:03 PM
Wheel Offset Warren Demontague 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 8 21st June 2007 09:59 AM
Wheel Offset Tycoo 9-5 Performance, Mods & Tuning 22 20th October 2006 04:13 PM
Wheel offset Retribution 9-5 Performance, Mods & Tuning 3 20th December 2005 11:51 AM
Wheel Offset 96Turbo NG900 & OG9-3 Performance, Mods & Tuning 0 22nd July 2005 02:03 AM
